12-20-2003, 03:44 PM
#1
I am interested in putting a 2" coil lift on a ZJ. I don't know too much about them, will they hold up for a long time? Are they easy to install? Any brands in particular I should buy? I just ordered 245 70 16 BFGoodrich AT/KO's to fill up the wheel wells. Thanks in advance!
Dave
Goodyear MT/R 245-75-16, Mopar PCM ECU, 52mm APS Throttle Body AND spacer, Flowmaster Exhaust, Homebrew K&N Intake, Summit 3" exhaust cutout, OME steering stabilizer, 2.25" B. Boost, ProComp MX-6 adjustable shocks,
Up-Country springs.
12-21-2003, 03:31 AM
#2
I think the spacers are great. I run them on both of my Jeeps. But I would recomend extended bump stops for the rear to help hold the spacers on. Without extended bumpstops it is almost certain that the spaces will pop out. They usually do not pop all the way out but they tend to lean toward one side of the spring which is not good. The front does not need extended bump stops.
98XJ, Front leaf spring conversion, 35x12.50 BFGs, dana44s front & rear,geared, locked.
87MJ, work in progress
12-22-2003, 07:15 AM
#3
Dave
I've got some 2" coil spacers that I had on for about 10 days. I ended up taking them back out when I gave the ZJ to my daughter.
They look brand new. PM me if your interested in them.
Jeff
'01 TJ with mods... :)
[COLOR=white][B]White[/B][/COLOR] Jeep Club Member #22
12-22-2003, 03:11 PM
#4
Jeep Jedi Master
Yep,
you'll start there and things turn bad quickly. You'll start parking next to smaller jeeps until someone with a lift parks next to you and then the mod fever sets in.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
12-22-2003, 07:45 PM
#5
Originally Posted by Texas ZJ1
Yep,
Hunter
Hehe. Yep! I have the 2" spacers and 31X10 1/2s . Love it. Just enough, not too much.
12-22-2003, 08:45 PM
#6
Do your 31's rub at all?
1997 ZJ 5.2L V8,K&N AIR FILTER,FLO-MASTER EXHAUST 2"BB LIFT 30" REMINGTON WIDE BRUTES. ProComp ES3000 SHOCKS, CUSTOM SPARE TIRE CARRIER AND ROOF RACK,HELLA LIGHTS. JUST GETTING STARTED!!!!!
1968 Jeep (Kaiser) Wagoneer, Buick 350 V8, Isky cam,HEI ignition, TH400 trans and completly stock inside and out.
12-23-2003, 09:31 AM
#7
On the lower controll arm at full lock on both sides. Not really a problem for what I do.
12-23-2003, 10:06 AM
#8
Yep,
Hunter
HAHA!! That is such a true statement! I already have a slight case of mod-fever (if you read my sig). I just ordered 245-70-16 BFG AT/KO I think it will look great with a 2" lift. Those tires should fill up the wells pretty well, well anyway hope all is well in the Jeepforum  Wow I'll stop now! Keep 'em comin' boys! It sounds like everyone likes the spacers...can't wait to put those bad boys on! Thanks for the replies!
Dave
Up-Country springs.
12-24-2003, 09:41 AM
#9
Hey just was reading what was on yout rig in your sig. You NEED to ditch that Jet chip. The 5.9L's ECM already is an advanced timing computer, the piggy back chips are only bad news in the long run. and for the rest of the ZJ'ers mopar makes a performance computer for the 5.2 and i think for the 4.0, the jet chips will skrew up yout computer and engine
95 ZJ 5.2L Custom long arm 8" springs BFG 35X12.5 JKS Quick Disconnects, JKS Barpin eliminators, Radiator support, K&N Intake, 180 Deg. thermo, self built rear bumper, flowmaster 1 chamber , highflow racing cat, Mopar Performance PCM, Kevins Rock Sliderz and high tac bar conversion, self built front bumper, NV231HD Conversion with Tera Flex SYE, Ford 8.8 rear axle, JKS rear adjustable Track bar, D44 knuckes, 4.56 gears, Warn manual hubs, Superior Chromy shafts
USAFROTC DET 20 UofA Best in the West
12-24-2003, 12:08 PM
#10
Never use the words 'performance' and '4.0' in the same sentance.
Darkness is deaths ignorance, and the Devils time.
'96 Grand Cherokee Laredo
'93 Taurus SHO
'77 Corvette L-48
'74 Land Cruiser FJ40
12-24-2003, 12:49 PM
#11
Finally someone else who understands that the aftermarket PROMs are just a waste of time and money.
2002 Jeep TJ Sport 4.0L Patriot Blue/Black Hardtop Dana 44
1996 Jeep ZJ Orvis fully loaded
1995 Pontiac Trans Am 5.7L - 6 speed
1928 Ford Model A - Street Rod Project
12-26-2003, 05:12 PM
#12
Hey, I am going to remove it like you suggest. I gained NO performance from the crap chip. I agree that it can't be good. How about the mopar performance ecu? I have heard they do a lot fo the performance of the 5.2 and 5.9.
Anyone interested in Buying a Jet Chip?!
Back to the spacers, what do ya'll think about them should I do it?? thanks!
Up-Country springs.
12-27-2003, 06:30 AM
#13
Jeep Jedi Master
You mean to tell me that the spacers aren't in yet? Come on...
Take some pics afterwards and post them. If you want to help others who might have the same idea. Post your pics over at www.nagca.com and there is a wealth of info on that website.
I have the Mopar Performance computer.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
