Coil rubbing bumpstop - JeepForum.com
post #1 of 6 Old 04-04-2013, 07:44 AM Thread Starter
sevenscrew
The driverside is rubbing the metal cup that use to house a rubber jounce bump stop. I tried crushing it with channel locks but I'm not strong enough to make it budge. Anything I can do without removing the coil
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #2 of 6 Old 04-04-2013, 08:18 AM
PolkaPower
Is the front axle centered?
PolkaPower is online now
post #3 of 6 Old 04-04-2013, 09:04 AM
WhiteOut
WhiteOut's Avatar
Is it rubbing on the side or the back/front of the bumpstop.
WhiteOut is offline
post #4 of 6 Old 04-04-2013, 09:52 AM Thread Starter
sevenscrew
The back sorry it's because I lengthened my uppers to make my pinion straight with the driveshaft (pointing at the t case output
Edit:
I will check to see if centering it better will help but it's only when slowly down or hitting bumps and spied bumps.
2016 2DR JK
post #5 of 6 Old 04-04-2013, 01:19 PM
PolkaPower
Edit:
The rear doesn't have to point right at the t case output.
post #6 of 6 Old 04-04-2013, 05:00 PM Thread Starter
sevenscrew
its the front axle Sorry for the way i worded it
My driverside FRONT coils prain, rubs on the BACKside of the bumpstop(cup shaped metal that holds the rubber piece).
The rubber inside it is missing so i dont care what i have to do to that cup i just want to not hear the sprungy noise every bump and deacceleration (stop signs )
i tried squeezing it with channel locks in hopes to just oval it alittle away from the coil but that didnt work. ic ant squeeze/bend it
2016 2DR JK
