Coil Problems - JeepForum.com
post #1 of 8 Old 10-18-2007, 01:03 PM Thread Starter
93JeepZJ
Coil Problems
Well my jeeps been in and out of the shop 3 times in the last 2 weeks. First time it was the coil, drove for about 20 miles and shut off... ended up being the distributer and coil. Drove it again for about 100miles until it shut off. They called and said it was the coil again. They researched the problem and i guess back in 1993 there was a service bulletin for the coil pack and wiring harness for it.
Next day i get a call and find out that there is only one kit left in the U.S. and its in hawaii and its going to be 3-5 days till they get the part! anyone else run into this coil problem?
'93 Jeep ZJ- 4.0L/249NP/42RE, 2" BB, 31" ProComp A/T's
'01 Monte Carlo SS- Supercharged/Cam/Headers
93JeepZJ is offline
post #2 of 8 Old 10-18-2007, 01:14 PM
93GrandZJ
you must have an early 93 with the pole type terminals on the coil. the later 93s (like mine) already had the "updated" coil and the harness you are talking about. it runs up to the alternator (i think) and is zip tied off to the alternator.
i have still replaced the "new coil" three or four times in 198+K miles. i can't remember if the harness will "upgrade" you to the newer coil...
93GrandZJ is offline
post #3 of 8 Old 10-18-2007, 01:15 PM
driabyor
driabyor's Avatar
1994 ZJ
I went thru several coils at one point. I bolted the first two back to the bracket , with the 3 foot long bolts.... I cussed both times... the third time,well the second coil is still on the jeep. the Third one is ziptied to the old coil... no problems for at least 100,000 miles.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 8 Old 10-18-2007, 01:19 PM
93GrandZJ
no kidding, they are long
post #5 of 8 Old 10-18-2007, 01:29 PM Thread Starter
93JeepZJ
i hoping that this will fix the problem and i can drive it for more then a day! i miss my jeep and i need to get it home so i can get some new tires on it before winter. all together with towing and repair bills this has cost me over $500 and its not fixed yet
93JeepZJ is offline
post #6 of 8 Old 10-18-2007, 01:35 PM
93GrandZJ
on mine when the coil(s) went it did not just shut off. it would sputter and spit and miss and eventually stall. you could get it started again, but it would do the same thing. if you did not keep on the gas it would stall.
sure it's the coil?
post #7 of 8 Old 10-19-2007, 12:31 PM Thread Starter
93JeepZJ
ya every time they replace it, it runs fine. the times it went out it would backfire and shut off then wouldnt start. i wish it would just spit and sputter... then i could get it home and fix it myself instead of paying $$$$ for repair bills at a shop
93JeepZJ is offline
post #8 of 8 Old 10-19-2007, 12:44 PM
CLNinja
CLNinja's Avatar
this is why i love the MSD coil i put on my 93 ( built in 92 )
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
Repeat Coil Pack Problems PreacherTJ ZJ Grand Cherokee Forum 2 05-12-2009 04:16 PM
Coil Sag ZJ-Soldier ZJ Grand Cherokee Forum 1 03-04-2009 09:17 PM
Mudding problems.....What do you guys do to prevent problems? JackAysJake ZJ Grand Cherokee Forum 8 02-23-2009 10:02 PM
Ignition coil problems the whole time maybe? speedbullet2 ZJ Grand Cherokee Forum 11 03-09-2008 02:15 PM
Alternator problems??? Shock problems??? rflem550 ZJ Grand Cherokee Forum 11 01-24-2007 07:41 AM
