Quantcast Code Retreive question for 2000 WJ. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Code Retreive question for 2000 WJ.
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 09-06-2007, 03:19 PM   #1
dturano547
I checked at wjjeeps.com and found the on.off/on.off/on.off/on but it does not seem to be working for me. is this the right sequence for a 2000 wj?
I wait till the odometer comes on then go back to off. I think I remember pulling codes a few months ago on this jeep but it could have been for my 96. when i called my local dealer he told me that does not work on jeeps newer then 96, but like i said im alomost positve i pulled codes for my jeep last year when i got it.
I have been searching the forum because i think i remeber finding another sequence a while back for my jeep, but cant seem to find that thread.
Any help would be greatly appreciated right now.
Most recent Jeep status can be viewed on the left, enjoy!
dturano547 is offline   Reply With Quote
Old 09-06-2007, 03:22 PM   #2
Briandl
Try holding the odometer reset button when you do it.
I think none of these tricks work on European WJ's, or some other country...
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline   Reply With Quote
Old 09-06-2007, 03:27 PM   #3
dturano547
that just made all the guages go bonkers while doing it, no luck.
Old 09-06-2007, 03:28 PM   #4
Briandl
Dunno, either have a foreign WJ, or you're doing it wrong.
I've never had a problem doing it on my 99 or my 02...
Old 09-06-2007, 03:33 PM   #5
dturano547
just to be sure im not doing anything wrong...
on (see mileage) completely off, on (see mileage) completely off, on (see mileage) completely off, then turn to on and leave it on...if there are no codes present i will see none?
thats the way im doing it, just wanted to be sure it was correct. am i doing it to quick or to slow?
Old 09-06-2007, 03:38 PM   #6
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You're doing it too slow.
Do not wait until you see the mileage.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 09-06-2007, 03:41 PM   #7
Briandl
Do it one less time...
Old 09-06-2007, 03:49 PM   #8
Briandl
Yeah sometimes I don't even get it, just keep trying, maybe like whats his name said, faster....
Old 09-06-2007, 05:20 PM   #9
rm2001wj
Confirmed Street Jeeper
rm2001wj's Avatar
On my '01 and my wife's '04, it's on-off/on-off/on. In other words, one less on-off cycle.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
Old 09-06-2007, 07:46 PM   #10
Briandl
That's why I said do it one less time, on mine it's the same as yours, I went outside and checked...
Old 09-06-2007, 08:25 PM   #11
sand zj
Like said befor on/off/on/off/on, you can do it quickly, just don't start it.
Dan
[B]If you don't get stuck, keep trying![/B]
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline   Reply With Quote
Glock Forum
