Code 720, Output Shaft Speed Sensor? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Code 720, Output Shaft Speed Sensor?
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 02-07-2009, 09:48 AM   #1
gmartin1215
Recently I got the code 720 for the Output Shaft Speed sensor failing. I tried clearing the code and driving, but the code came back. So, looks like I need to replace this.
The info I got is that this is near the rear of the transmission and on the left. How hard is it to replace this thing?
Is this a stealer only part??
gmartin1215 is offline   Reply With Quote
Unread 02-07-2009, 02:10 PM   #2
gmartin1215
Ok, I got the part from the dealer, $23. Not bad. But now my question is where exactly is it. Looking underneath I do see a sensor on the overdrive part of the transmission on the left hand side near the bottom, just in front of the cross member. Could this be it?? Or is it the one just above the tranny pan where all the linkage is??
Unread 02-07-2009, 03:31 PM   #3
Igota94Grand
If it is 4x4 it will be on driverside of transfer case near the top
Igota94Grand is offline   Reply With Quote
Unread 02-07-2009, 04:00 PM   #4
gmartin1215
Thanks.
But it was the one on the overdrive just in front of cross member. It had the same part number as the part I got from dealer. I swapped these out, reset the computer, took it for a drive and the check engine light did not come on! It also shifted better!
Unread 02-08-2009, 01:11 PM   #5
Igota94Grand
Of course. Maybe i should reset my computer after changing my vss and tps. thanks, never thought of it
