Code 37 help 97 zj 2wd laredo - JeepForum.com
post #1 of 2 Old 04-29-2013, 04:32 PM Thread Starter
97ZJ-Ryan95
I started up the jeep this morning and drove maybe half a mile before I heard the ping of and see the check engine light turn on. Pull into a parking lot, turn it off and on, runs perfectly. Drive another 3 or 4 miles and decide to take it home and run the codes. Got code 37, looked it up and found it was a circuit/solenoid related to the torque converter. I've done some searching through threads on here and haven't found a way to diagnose exactly what needs to be fixed.
It was driving and shifting as usual the whole time. I have tools at home and can find parts but have no idea where to find the various places to check sensors. I saw somewhere that there is a plate on the front of the transmission. Is there anything in there that I should inspect and would I have to drop or remove anything to get to it.
1997 ZJ I6
2wd, d35 w/ positrac. I believe the transmission is 42re.
97ZJ-Ryan95 is offline
post #2 of 2 Old 04-29-2013, 08:06 PM Thread Starter
97ZJ-Ryan95
Update p0753 - trans 3-4 shift sol/trans relay Circuits.
Current state if output port for the solenoid is different from expected state. I drove the jeep and let it run through the shifts, worked perfectly, any way to clear the code or check the actual solenoid?
Thanks in advance
