Code 1757 - JeepForum.com
post #1 of 7 Old 08-13-2012, 06:38 PM Thread Starter
first98J
1998 WJ
Code 1757
I ran obd2 and found code 1757 Please help. What is a govenor pressure sensor obd2 says gov pressure sensor is over 3 psi when 0 is requested. what are the steps in resolving this problem and where can i find one to buy?
first98J is offline
post #2 of 7 Old 08-13-2012, 10:39 PM Thread Starter
first98J
1998 WJ
It will not shift into third or forth, second gear is a chore to get it to shift. After driving it kicked this code. P1757. any help?
first98J is offline
post #3 of 7 Old 08-13-2012, 10:41 PM Thread Starter
first98J
1998 WJ
Sorry its a 2wd 4.0 zj
first98J is offline
post #4 of 7 Old 08-13-2012, 10:43 PM
tizzly
1994 ZJ
sounds like the pressure solenoid and sensor in the trans, i could be wrong tho
if so its not too hard to fix
tizzly is offline
post #5 of 7 Old 08-14-2012, 12:16 AM
JustN11
It's time to replace the Governor Pressure sensor. You'll need to drop the tranny pan and filter to get to it. You will see the sensor inside a mounting case. There's a YouTube video on this exact problem. Search your trouble code with the word grand Cherokee and you should find it easily. I am on my phone or else I would post it for you, but I'll let you do the work.
JustN11 is offline
post #6 of 7 Old 08-14-2012, 07:22 AM
FAlfani81
edit...
FAlfani81 is offline
post #7 of 7 Old 08-14-2012, 08:00 AM
melk
Replace both the pressure sensor and solenoid.
I paid $50 + $75 locally.
melk is offline
What does code check engine code 14 mean?? tawa1075 ZJ Grand Cherokee Forum 1 10-19-2010 03:54 PM
Engine Code help- Code 11 athomas08 ZJ Grand Cherokee Forum 3 05-07-2009 12:56 AM
How to fix code 15 zjeepin ZJ Grand Cherokee Forum 8 02-25-2008 08:46 PM
threw the 1757 diagnostic code, please help Brad00Jeep ZJ Grand Cherokee Forum 4 03-22-2005 08:23 AM
OBDII CODE 1757 Governor Pressure zoom248 ZJ Grand Cherokee Forum 0 05-20-2004 08:33 PM
