Clutch fan and electric fan combo - JeepForum.com
post #1 of 14 Old 07-18-2013, 05:58 PM Thread Starter
just_urd
Has anyone used an electric fan and clutch fan somehow? Just curious if it can be done, and if any cooling benefits can be achieved in doing so....
just_urd is offline
post #2 of 14 Old 07-18-2013, 06:02 PM
dnuccio
im sure it could be done. just mount the electric fan in front of the radiator and leave the clutch fan where its at.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 14 Old 07-18-2013, 06:03 PM
OldManTan
actually thought about this today as well haha
Don't the early WJ's have both?
probably not enough room though. It's pretty snug back there with my Taurus fan swap
OldManTan is offline
post #4 of 14 Old 07-18-2013, 06:12 PM
ghiotom
I think mechanical fan as a puller and an electric fan as a pusher could be done, but the pusher would have to be small and since they aren't as efficient as a puller fan, it's probably not worth it. Is this to keep engine temps in line or to improve ac performance?
ghiotom is offline
post #5 of 14 Old 07-18-2013, 07:49 PM Thread Starter
just_urd
I was possibly thinking of moving the shroud, and putting an electric fan in front of the mech fan (if it'll fit), then putting the shroud back into place.
I guess if it'll improve cooling and help the a/c, why not...
I'm mainly curious if anyone has attempted this.
just_urd is offline
post #6 of 14 Old 07-18-2013, 07:52 PM Thread Starter
just_urd
My friends durango has this set up stock, as well as another friend of mine with an xterra. Pretty sure the early WJ's come this way as well, not 100%.
just_urd is offline
post #7 of 14 Old 07-18-2013, 08:14 PM
MeanGreenZJ
Not enough clearance for both.
MeanGreenZJ is offline
post #8 of 14 Old 07-18-2013, 08:24 PM
Mickey_D
RENIX XJ's had both. The electric was activated by the A/C. But they were side by side.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #9 of 14 Old 07-18-2013, 08:45 PM Thread Starter
just_urd
That's what my 87 XJ had. It was a fifty fifty chance it ever worked, among everything else on that jeep.
just_urd is offline
post #10 of 14 Old 07-18-2013, 08:51 PM Thread Starter
just_urd
Not even for an ultra thin aftermarket fan?
just_urd is offline
post #11 of 14 Old 07-18-2013, 10:02 PM
MeanGreenZJ
Nope not a chance. Just ask anyone that has a 5.9
post #12 of 14 Old 07-19-2013, 12:10 AM
dnuccio
theres maybe an inch of space between the clutch fan and the radiator
R.I.P. Ratmonkey
dnuccio is offline
post #13 of 14 Old 07-19-2013, 12:25 PM
zjosh93
All the OEM setups like that that I've seen were side by side.
I don't see how it would help in any case. A properly sized clutch fan with a good fan clutch should be able to cool just fine. I know a lot of guys have troubles cooling a ZJ with the factory setup but in my opinion adding a pusher to the front probably won't help much. Pushers are very inefficient unless they have very good shrouding. Adding that shrouding would be very difficult in front of a ZJ and with two shrouds you'd probably loose a lot of air flow.
Plus, the electric fan becomes a restriction at roadway speeds. The clutch fan will still be there causing drag on the motor. Sounds to me like you'd get the worst of both fans.
I may be wrong though, only one way to find out.
zjosh93 is offline
post #14 of 14 Old 07-19-2013, 12:55 PM Thread Starter
just_urd
Another thing I was thinking if it could be accomplished would in fact be restriction like you mentioned.
I probably won't attempt this, it was mainly just a thought, and if anyone has tried this out.
I changed the water pump, 195 thermostat, radiator, hoses, and clutch when I bought the jeep (all appeared to be original) just for safe measure.
All is normal with the cooling, just thought of an updated upgrade like some newer vehicles contain, just to keep the temps a little more stable per say.
just_urd is offline
