Clunks when turning, interesting solution. - JeepForum.com
post #1 of 3 Old 10-11-2009, 07:44 PM Thread Starter
the88thpianoman
2003 WJ
So for several months now, I've been getting a clunking sound and feel every time I turn with any momentum, in a new direction. Something was obviously being moved back and forth. First mechanic told me it was the ball joints, so I got those replaced, not the problem. Then another mechanic said it was bad control arm bushings. After doing some reading here, I figured it was bad track bar bushings and the bolt hole starting to oval out, so I've just been living with it till I lift and replace my track bar and get some washers welded up. Fast forward like 7 months.
I'm under the Jeep today just looking at stuff (am I the only one who does this when I'm not looking for anything specific?) and I finally notice the culprit. The nut on the bolt that holds the trans and the trans mount together had backed almost completely off. My entire transmission/transfer case/drive shafts had been shifting back and forth on every turn by nearly an inch. I tightened the hell out of that nut and bolt and took it for a drive. No more clunks.
The track bar seems like the obvious culprit for this problem, but it is well worth glancing down at that trans mount just in case.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #2 of 3 Old 10-11-2009, 07:49 PM
Inavacuum
wow, that is scary. That is why every time I get home from wheeling or a long trip I do just what you said and just lay on a creeper and look at stuff.
95 ZJ 4.0 PART OUT: Silver Body; Grey Cloth interior
HPD30;RE BB w/ RE Shocks;KOR Rad Support
KOR XMember/TC Skid
Make an offer on anything you're interested in.
Inavacuum is offline
post #3 of 3 Old 10-11-2009, 07:53 PM
iowaboostin
Damn, same thing happened with an old Mitsubishi Eclipse of mine. The transmission almost literally "dropped."
1995 Jeep Grand Cherokee Laredo
1997 BMW 328i
iowaboostin is offline
ZJ sputters then clunks RiverMCK ZJ Grand Cherokee Forum 9 06-20-2011 01:14 PM
Creeks and clunks Haleyrz ZJ Grand Cherokee Forum 12 11-06-2008 03:41 AM
other causes of clunks/pops Derek33 ZJ Grand Cherokee Forum 13 07-25-2007 04:35 PM
Clunks Into reverse ?? jeepunlimited ZJ Grand Cherokee Forum 0 11-09-2006 01:08 PM
clunks in reverse Derek33 ZJ Grand Cherokee Forum 3 01-01-2006 02:09 PM
