Clunking sound from front end - JeepForum.com
post #1 of 5 Old 07-19-2009, 09:40 AM Thread Starter
kmo0189
I have a 2000 wj and recently when turning left I hear a clunking/popping sound coming from the front end. Only when turning left though. I tried to locate where it was coming from and it looks like maybe the drag link. I am not sure if the drag link is supposed to be loose, but mine is a little loose. I've been reading up on it and it looks like maybe the drag link ends need replacing. Does this sound like the problem? Any other suggestions? Thanks.
kmo0189 is offline
post #2 of 5 Old 07-19-2009, 11:29 AM
bigzj
Mine makes a similar sound only when i turn left. Mine is caused because i put BFG 30/9.5 A/T's without a lift, so im rubbing my tread against my wheel well.
bigzj is offline
post #3 of 5 Old 07-19-2009, 11:55 AM
cloiselle
check your rear a arm bushings and you rrear control arm bushings.
also check your shock mount bolts, for looseness or play .
cloiselle is offline
post #4 of 5 Old 07-19-2009, 11:56 AM
cloiselle
pm me for any other question i'd be glad to help. mine clunked in the rear for a while all new bushings ( control arms, a arm and sway bar bushings solved the problem )
i did once get gravel in my e brake which took ages to figure out the source of the sound :/ that was not cool !
post #5 of 5 Old 07-20-2009, 01:52 AM
sandman
when i get a clunking i get under my jeep with a breaker bar and make sure everything is tight. most of the time i find something loose and fix my clunk.
1993 Jeep ZJ. 4.0
sandman is offline
Clunking sound in front...97 ZJ Evolved ZJ Grand Cherokee Forum 4 02-19-2009 12:26 AM
clunking sound comes from the front end stiller ZJ Grand Cherokee Forum 10 12-30-2008 10:00 PM
front passenger tire DW. Loud clunking sound. slagehammer ZJ Grand Cherokee Forum 2 07-27-2008 03:06 AM
Clunking sound from the front end nicks5.2 ZJ Grand Cherokee Forum 7 01-17-2008 02:27 PM
Front end *clunking* sound... O Holy P ZJ Grand Cherokee Forum 3 09-24-2004 05:11 PM
