clunking noise in back left tire area - JeepForum.com
post #1 of 20 Old 07-28-2006, 06:09 PM Thread Starter
bearlax4
Ok so i had already made this thread but i thought it was my shocks..turns out its not i went to so much trouble that i put my old (stock) shocks i and took out the MX-6s....still the clunk
helpp!
thanks
Grant
2004 Jeep Grand Cherokee Freedom Edition
2.5 In Kolak BB with MX-6s
31" toyo AT open country tires
PIAA 9005/9006s/PIAA 525-Waag Brush Guard
Focal and JL sound system=(400 wat 4channel AMP/300 Wat mono channel sub amp) with Pioneer DVD navigation
bearlax4 is offline
post #2 of 20 Old 07-28-2006, 07:11 PM Thread Starter
bearlax4
anyone have any thoughts?
Grant
bearlax4 is offline
post #3 of 20 Old 07-28-2006, 07:26 PM
jeepdude06
check ball joints by jacking up the rear tires and if u can push in on the top of the tire and it rocks back and forth more than likely u have a bad ball joint, either that your lug nuts are loose lol
jeepdude06 is offline
post #4 of 20 Old 07-28-2006, 08:34 PM Thread Starter
bearlax4
gotcha thanks man
if the ball joints are messed up...what will it cost to fix it any ideas?
Grant
bearlax4 is offline
post #5 of 20 Old 07-28-2006, 10:38 PM
jeepdude06
ummm, if u take it to a shop and have them do itll itll cost up the wazu, but if u do it yourself (which is a ***** and a half lol) itll cost about $80 roughly i think
post #6 of 20 Old 07-28-2006, 11:43 PM
stogiejeep
My best guess would be ball joints also. Have you greased them lately?
Fettuccini Alfredo is Maccaroni & Cheese for adults.
-RIP Mitch hedburg
stogiejeep is offline
post #7 of 20 Old 07-28-2006, 11:47 PM
Arkansas_WJ
Arkansas_WJ's Avatar
my spare gave me hell for a month...actually it was the jack down there
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #8 of 20 Old 07-29-2006, 12:35 AM
Chrisca
Chrisca's Avatar
Rear sway bar bushings.
2004 Grand Cherokee Laredo
Chrisca is offline
post #9 of 20 Old 07-29-2006, 12:55 AM
-Joe-
-Joe-'s Avatar
Theres balljoints in the rear?
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #10 of 20 Old 07-29-2006, 01:05 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Stop the insanity!!!!
There are no ball joints in the rear.
If you have play in the tires when it's on jacks, you need new bearings and probably other items.
It's one of three things. Control arm bushings, sway bar bushings, or track bar.
Check all those and see where you are at.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #11 of 20 Old 07-29-2006, 01:13 AM
-Joe-
-Joe-'s Avatar
See.. someone knows where thier ball thingies are..
Might check your muffler too, see if its loose and banging on anything.
- Joe -
-Joe- is offline
post #12 of 20 Old 07-29-2006, 12:24 PM Thread Starter
bearlax4
Check all those and see where you are at.[/QUOTE]
how do i check those 3 things?
Grant
bearlax4 is offline
post #13 of 20 Old 07-29-2006, 12:54 PM
Woody
Woody's Avatar
1985
Raise the rear of the Jeep on jackstands. Pull on the control arms and track bar and look for any movement.
For the sway bar, look at it and verify everything looks normal and then attempt to move it by hand. I think some WJ's don't have a rear sway bar, so if you don't have one, no big deal.
Woody
Woody is offline
post #14 of 20 Old 07-29-2006, 01:19 PM Thread Starter
bearlax4
ok thanks man ill get back to you' all and let you know whats going on
question tho: why would my control arms already have problems i only have 23000 miles on it
Grant
bearlax4 is offline
post #15 of 20 Old 07-29-2006, 01:42 PM
Woody
Woody's Avatar
1985
Some folks drive 240K on theirs with no problems. Others drive 10K and have issues.
Quality control at Chrysler is still a problem. I know several folks who've had to get Hemi engines replaced as well as their trannys.
It doesn't help that they switch parts manufacturer's so often that it seems like nothing ever stays the same for more than a year or so. Causes lots of parts problems.
Woody
Woody is offline
Weird noise from driver rear tire area PolishAir42 WK Grand Cherokee & XK Commander Forum 0 08-02-2009 12:24 AM
clunking noise on back of my 06 GC lance70 WK Grand Cherokee & XK Commander Forum 4 04-03-2009 01:26 PM
Clunking noise from right rear tire (Question) onrails ZJ Grand Cherokee Forum 3 11-07-2006 03:41 PM
wierd noise in back left shock? cont bearlax4 ZJ Grand Cherokee Forum 6 07-12-2006 08:09 AM
wierd noise in back left shock? bearlax4 ZJ Grand Cherokee Forum 9 07-05-2006 09:43 AM
