Clunking in front passenger wheel area - JeepForum.com
post #1 of 5 Old 01-10-2013, 06:34 PM Thread Starter
bravekate
I have a 1998 JGC....problem is getting worse. When I am coasting slowly or just starting to accelerate the clunking is very bad. It disappears when I step on the brake. Will be replacing shocks this weekend and would like to address this problem at the same time. Any ideas?
bravekate is offline
post #2 of 5 Old 01-10-2013, 06:41 PM
riot1987
Control arm bushings?
Maybe a loose caliper?
Loose shock?
Build thread^^
riot1987 is offline
post #3 of 5 Old 01-10-2013, 06:44 PM
riot1987
Front or rear? What side?
Build thread^^
riot1987 is offline
post #4 of 5 Old 01-10-2013, 06:45 PM
Y0ungGunZJ
for the control arm bushing, if you are in a parking spot or the drive way put your foot on the brake and go from drive to reverse and if its really bad you'll hear it while you are doing that. or if you go down a wash or bumpy dirt road you'll hear it knock back and forth.
its says front passenger on the title
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #5 of 5 Old 01-10-2013, 07:05 PM Thread Starter
bravekate
Yes....front passenger. I'll check the drive to reverse when I start it (IF it starts) in the morning. I just want some ideas when I have the wheels off for the new shock installation. I'm also having the dreaded stall/not starting issue. Just going down the list when I can.
brakes , clunking , front end
