clunk when releasing gas pedal - JeepForum.com
post #1 of 19 Old 10-02-2005, 11:43 PM Thread Starter
laphan
Hi all,
I'm currently having an issue with clunking noise when I release the gas pedal (more noticeable in lower speed). Its not too loud but anoying. I checked the u-joints on the drive shaft but it seems to be fine (no play whatsoever). Anyone has any idea whete should I start to fix this problem ?
Thanks
98 ZJ, 4.0L I6, 42RE, NP242.
Upgrades: mopar skid plates, mopar tow hitch, Hayden transmission cooler, OME SS, DT8000 pre-runner shocks, Kevin's Radiator Support, 2" BB, Bridgestone Dueler A/T revo.
laphan is offline
post #2 of 19 Old 10-03-2005, 04:29 PM
CJjacquez
Have you checked engine and tranny mounts??
CJjacquez is offline
post #3 of 19 Old 10-03-2005, 04:35 PM
FatAlbert
I have the EXACT same problem right now with my ZJ... I'm looking foward to any further information.
2012 WK2 :: V6
FatAlbert is offline
post #4 of 19 Old 10-03-2005, 08:30 PM
Arkansas_WJ
Arkansas_WJ's Avatar
It is also happening with my wj.
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #5 of 19 Old 10-03-2005, 08:33 PM
JeepingOverYou
x3 on my ZJ. especially in traffic, its so annoying
1996 ZJ Laredo 4.0L 241k+
Jeep
[__] ||||||||| [__]
JeepingOverYou is offline
post #6 of 19 Old 10-03-2005, 08:39 PM
Yardman Harry
O
Yardman Harry's Avatar
i have that problem too, and it also happens a lot when i hit a bump. i checked the front end, had the wheels aligned, replaced the stabilizer shock, everything is fine.
i have come to the conlcusion that the tranny mounts or the engine mounts are bad, but i just cant find where, does anybody have any tests?
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #7 of 19 Old 10-04-2005, 10:23 AM
FlashLCD33
X11ty billiion
Going down the road, if I tap on the gas and let off real fast while going about 15mph or so you can hear it clunk pretty bad. Kind of annoying.
'93 Grand Cherokee Larado 4.0l - 4wd - Wrecked.
FlashLCD33 is offline
post #8 of 19 Old 10-04-2005, 11:13 AM
RyanZJ
RyanZJ's Avatar
I have the same clunk, and after crawling around under the heep last night I think I've narrowed it down to where the front driveshaft enters the transfer case.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #9 of 19 Old 10-04-2005, 12:34 PM
shadetree
yep, mine does the same thing! I'm gonna replace my rear u-joint and if that don't fix it then I'm going to assume my rear differential is getting sloppy and I already have plans to re-gear it when I get back from Iraq. 4.56's and lockers. Anyway I think that the latter thought for the problem is true ie..backlash and worn gears.
Any thoughts along the same lines?
"If I can't buy it or borrow it, I don't need it"
-1994 ZJ Lifted and Locked...
-1983 CJ7 4.2ltr/Dana 300/Warn F&R bumpers...and some other goodies.
D.W.A. (Death Wobble Anonymous)
shadetree is offline
post #10 of 19 Old 10-04-2005, 12:54 PM
Decipticon
Just a thought...check your exaust system. A loose or broken hanger can cause a muffler or pipe to bang on things during acceleration/deceleration and bumps. Its worth crawling under the Jeep and looking for a few seconds.
Jesus is coming. Look busy.
Decipticon is offline
post #11 of 19 Old 10-04-2005, 12:56 PM Thread Starter
laphan
I just sent the jeep to mechanics and he said something in the driveshaft u joints came loose (seal). He tightened it and it drives alot better now but still can hear the clunk so I left it in his shop until he can get rid of those clunks.
I will let you guys know after I get my POS jeep back from the shop
laphan is offline
post #12 of 19 Old 10-04-2005, 01:50 PM
gpJeep
There was also a tsb on this for a certain model and year , can't remeber but i think it was early 2000 for a few months
it was fixed by nickel plating the inner tranny parts ...
gpJeep is offline
post #13 of 19 Old 10-04-2005, 02:09 PM
Arkansas_WJ
Yeah i have a very early 2000 and it is making the noise..i would take it into the shop but i would want to have some more info first and see if it is even a big deal.
Mitch
post #14 of 19 Old 10-04-2005, 02:14 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Yes, if all the mounts are solid, and its not ujoints, then driveline slop. Diff backlash, stretched TC chain, and thrust washers in the transmission clutch packs are places to look.
HighLonesome is offline
post #15 of 19 Old 10-04-2005, 05:43 PM
shadetree
gtg, I'm looking in the right direction! thanks
WJ 242 TC not releasing from 4x4 mode EisBlade ZJ Grand Cherokee Forum 7 12-19-2009 03:37 PM
New RE Twin Tubes + Cold = clunk clunk clunk? DHRFX Joe ZJ Grand Cherokee Forum 12 01-23-2009 08:03 AM
Thunk when releasing gas pedal samsdad ZJ Grand Cherokee Forum 14 03-23-2007 08:28 PM
Noise when releasing my brake, help! will_b ZJ Grand Cherokee Forum 5 02-13-2007 08:50 PM
Clunk clunk front end suspension noise. Need help/advise. jeep_zj98 ZJ Grand Cherokee Forum 11 01-02-2007 10:22 AM
