Clogged AC drain tube? - JeepForum.com
post #1 of 15 Old 11-12-2006, 01:10 PM Thread Starter
lma1973
It sounds like there is a waterfall going on behind the passenger side of the dash. At first i thought it was just the coolant moving around in the coolant reservoir, but someone on here suggested a clogged drain tube. Here are the instructions i followed:
http://www.aircondition.com/tech/questions/4/__print
Well, i drilled the hole and nothing. No water at all. I got a coat hanger and ran about 10 inches of it through the hole to "unclog it" but still nothing.
What could the water sound be coming from and any ideas on how to fix it? Thanks in advance.
2005 Jeep GCL Hemi
Gibson 3" catback exhaust
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #2 of 15 Old 11-12-2006, 04:46 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Do you hear it with AC or heat on? Maybe it's your heater core or the evaporator?
zaq123 is offline
post #3 of 15 Old 11-13-2006, 12:01 PM Thread Starter
lma1973
I usually hear it when i take off from a stop...like water sloshing around...doesnt matter if AC or heat is on. Also doesnt do it when driving down the road.
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #4 of 15 Old 11-13-2006, 06:56 PM Thread Starter
lma1973
Back to tha top
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #5 of 15 Old 11-13-2006, 07:03 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Try to have somebody rock your jeep while you're looking under the hood/dashboard area. That's how I pinpointed a few noises that drove me crazy on the trail
zaq123 is offline
post #6 of 15 Old 11-14-2006, 12:18 AM
sgarlic
Yeah, chances are you've got a ton of water sitting in there. I had that too, and drilling the hole didn't help. It's clogged up above the hole, probably not straight out like most people fish the coat hangar around in. That TSB is sort of misleading. What gets clogged is the drain passageway, not the hole leading to the outside of the vehicle.
You have to bend a coathangar and run it all the way up to the HVAC case, which is about a foot up. You also need to really move it around in there, because the "tube" is actually a passageway that's about 1 1/2 inch around. Once you hit the real clog, water will come pouring out of there. It might help to have the A/C running while you do this, because the air moving past the core will help push the water downward toward the tube.
Another guy here, and myself, ran secondary drain tubes from this hole to the floorboard on the passenger side, as a backup in case the actual hole itself gets plugged.
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
post #7 of 15 Old 11-14-2006, 08:36 AM Thread Starter
lma1973
Thanks for the replies. I'll try running a hanger way up there and see if that'll do it. It does sound like a ton of water in there!!
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #8 of 15 Old 11-20-2006, 07:20 PM Thread Starter
lma1973
Well i ran the coat hanger up their prob a good 18 inches or so and nothing. Still sounds like a ton of water in there. If im idling in neutral, i can stomp the gas and it will make the water move in there. Ive got gallons it sounds like!
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #9 of 15 Old 11-20-2006, 07:48 PM
-Joe-
-Joe-'s Avatar
I know the weather isnt great for this. But did you try to turn the AC on and see if you get anything from the drainage tube? If so you can rule out it being clogged.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #10 of 15 Old 11-20-2006, 07:56 PM
sgarlic
I'm telling you, mine made that exact same noise before I replaced it. Same sound, did it with rev's, etc.
sgarlic is offline
post #11 of 15 Old 11-22-2006, 11:13 AM Thread Starter
lma1973
Yeah i was running the AC at the time i was taking the coat hanger and trying to unclog it. It must be clogged so high up that i cant even get to it with a hanger. My question is why cant i get to the opening under the hood? If debris was able to find its way in there and it appears to be clogged very high up, cant i just follow the same path the debris took to get in there?
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #12 of 15 Old 11-25-2006, 03:49 PM
Bliss Racing
THis is the thread i've been looking for....i tried running the hanger....no water coming out, but seems to be less noisey. We'll see when i take it jeep out again.
Bliss Racing is offline
post #13 of 15 Old 11-25-2006, 06:48 PM Thread Starter
lma1973
Ive tried everyting i can think of and ive still got a ton of water up there...oh well, its just gonna have to stay that way!
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
post #14 of 15 Old 11-26-2006, 01:03 PM
sgarlic
Have you been adding stop leak or regular refrigerant refill cans with oil included? If so, you also probably have a ton of that liquid inside the evaporator.
sgarlic is offline
post #15 of 15 Old 11-26-2006, 06:32 PM Thread Starter
lma1973
Yes i did charge my AC early this summer and it was with a refrigerant can with oil added. To be honest, im not sure if i had the "water sound" before that?
2005 Jeep GCL Hemi
Airaid Intake
Superchips Flashpaq
lma1973 is offline
Repairing a Clogged AC Drain PunisherZJ ZJ Grand Cherokee Forum 163 10-15-2017 10:46 PM
Condensation Drain Tude: Clogged sandblaster426 ZJ Grand Cherokee Forum 15 07-12-2014 09:09 PM
a/c drain clogged 97zjjeeper ZJ Grand Cherokee Forum 5 07-29-2008 05:45 PM
A/C Drain clogged...3 inches of water...UHOH!! li'l jeep ZJ Grand Cherokee Forum 2 07-27-2008 02:20 PM
AC Drain Tube tek2977 ZJ Grand Cherokee Forum 13 05-11-2006 03:07 PM
