clocking zj transfer case - JeepForum.com
post #1 of 9 Old 05-08-2013, 01:00 PM Thread Starter
speedbucket
zj cases hang too low, I know iron rock has a clocking template for 50$ but I want to know if anyone else has done it.
I'm gonna use one of the cases I have laying around to make a template from plywood, then redrill the clocked holes . bolt the plywood up and drill clocked holes. Test fit it on the case studs before drilling the tranny flanges
Any thoughts?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #2 of 9 Old 05-08-2013, 01:32 PM
Technohead
Correction. 242's and 249's sit too low.
Get a 231 and you will be fine. My 231 sits well above my Clayton cross member. I've been wheeling it for years without a skid plate.
-Eric
Technohead is offline
post #3 of 9 Old 05-08-2013, 02:20 PM Thread Starter
speedbucket
I've already swapped in a 231. My zjs a 93 with v8 so the longer driveshaft you would have to clearance the Clayton cross member.
I'm building a similar 3 piece x member to claytons but with everything tucked a little tighter. I may even push it back to get under the CV joint.
But with another 2-3" I can get a true flat belly
post #4 of 9 Old 05-09-2013, 11:30 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Flat Won't happen without some significant floor massage work.
My 231 is as high as it gets without beating the floor to death.
ratmonkey is offline
post #5 of 9 Old 05-09-2013, 11:45 AM Thread Starter
speedbucket
Got any pictars? id like to atleast keep it flat from bottom of rear crossmember to front cross member if possible
to me it looks like it might work and make quite a bit of difference
factory...
clocked 7* or so
the floorboard may "get massaged" for a full clock if necessary
post #6 of 9 Old 05-09-2013, 03:11 PM
Technohead
If you need to clock the t-case then its time to scrap the zj and start building a buggy.
-Eric
post #7 of 9 Old 05-09-2013, 03:29 PM Thread Starter
speedbucket
If only..........but, I figure we lift these things for ground clearance and bigger tyras, so if I can drill 6 holes and net 2" of GC then its worth it. I gotta replace my tranny output seal anyways
I'll mess with that before I finish weld my crossmembers.
post #8 of 9 Old 05-09-2013, 03:30 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
why? flat belly is where it is at no matter what you wheel. one less thing to hang up, and as low as they hang on ZJ's why not clock it up.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #9 of 9 Old 05-10-2013, 02:19 PM Thread Starter
speedbucket
and just so everyone that finds this thread or searches "249 vs. 231" or "242 vs. 231".......this is why a 231 is beneficial over a 249 or 242.
249 left, 231 right.
and the second pic is of the linkage i made to get rid of the factory garbage
