Climate Control Woes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Climate Control Woes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread Yesterday, 06:33 PM   #1
dflewelling
Hi all,
Having issues with the CC on my 95 ZJ.
Here's the scoop: With the fan on high on heat or cool, and pertaining to the dash vents only, I'm not getting sufficient flow. The floor vents kick out plenty of air, but the on the dash vents, only in the center two vents give flow, and little at that.
I did a bit of reading, and I guess I'm supposed to look for a blend door vac line? I've looked and looked, but can't seem to find where said vac tube is.
Also, anything else I should check while down there?
Greatly appreciated.
dflewelling is offline   Reply With Quote Quick reply to this message
climate control , heater , vent
