Climate Control lights/illumination - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Climate Control lights/illumination
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-11-2015, 02:04 AM   #1
Minndave13
Ok, I am having a problem I cannot seem to locate. I have a 1997 Jeep Grand Cherokee Limited with the 4.0 six cylinder motor. When I got the vehicle some of the dash lights did not work and the headlights would flicker. Last weekend I went thru the headlight switch and replaced all the dash lights. The problem is that I cannot get the climate control lights to work. I did take the climate control out of the vehicle, took out the lights and cleaned the contacts but still nothing is working. I should also note that I did unplug the larger Blue connector, but there is a smaller area for a connector on the rear of the climate control also. Is this for the lights/illumination? I have searched the wiring in that area of the dash and cannot find any connectors.
Minndave13 is offline   Reply With Quote Quick reply to this message
Unread 03-12-2015, 10:04 PM   #2
Minndave13
Well I took a trip to the local Junkyard then went to the 97 I have been taking parts off of ( I already had taken apart the dash to purchase the VIC for $20). Knowing this vehicle had everything like mine I was sure I might locate the connector i was looking for. I was able to take a good hard look at the wiring for the VIC and everything else in the area. No luck on finding any 6 pin connector that would plug into the rear of the climate control. Now I am wondering what this connector pin set is even used for.
Would anyone have the wiring diagrams for the climate controls/ VIC area? I am looking for the wires that control the illumination for the climate control. What wire(s) control these lights????
