Climate Control blower stop working - JeepForum.com
post #1 of 35 Old 03-02-2006, 09:00 PM Thread Starter
bost1217
I have a 2004 Grand Cherokee Limited with the Automatic Climate Control. After turning the A/C on the blower turned off after about 5 min. I shut down the vehicle and waited about 15 min. and restarted. Again, the blower turned off after about 5 min. Approx. 3 hrs. later the blower doesn't work at all. I ran the self test and it gave a code 52. I know what that is but why did the blower motor stop?
bost1217 is offline
post #2 of 35 Old 03-02-2006, 09:57 PM
10achik
I ate what?
10achik's Avatar
Quite possibly it's the resistor pack under the dash. Turn it on and get down in the floorboad on the passenger side (under the glove box all the way in the back) and wiggle the plug that goes into the resistor pack. If it comes on then it's the plug, I got so tired of messing with it, I cut out the plug and soldered the wires directly to the pins in the resistor pack. Your's should be under warranty, take it in and have them fix it. It's actually a common problem because of the way the wiring has to come down and make a sharp 180 turn back into the pack. Poor planning IMO.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 35 Old 03-03-2006, 07:31 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Many of us have had the same problem with the resistor pack.
Your code 52 is also a potentially major problem, which indicates there is a problem with the blend doors or the recirc door (I can't remember which one this code refers to). Either way, if one of these door assemblies is faulty, it requires pulling the dash which is a major PITA.
If you're under warranty, definitely get it in for this ASAP.
Wheelin98TJ is offline
post #4 of 35 Old 03-04-2006, 06:39 AM Thread Starter
bost1217
Thanks for the info. I just reached 40,000 miles so the warranty for that is out.
bost1217 is offline
post #5 of 35 Old 03-04-2006, 12:19 PM
10achik
I ate what?
10achik's Avatar
Does that seem to be the problem for you, did you check the plug, it will probably even be melted a little. If so, do a search on resistor pack here and you will probably find a write up on how to do what I was talking about. Really good one!
Ken
2006 Pontiac G6 GTP
10achik is offline
post #6 of 35 Old 03-07-2006, 04:00 PM Thread Starter
bost1217
It worked!!!
I checked the resistor pack wiring and thats what it was. I now see what you mean about bad design. It is kinda awkward. THANKS!!!!
bost1217 is offline
post #7 of 35 Old 03-07-2006, 06:12 PM
Briandl
Who is willing to spend a few minutes filing a complaint with the NHTSA?
I already have and I'm willing to give more info for those who are willing to take the time to do it.
To make a long story short this problem should be a recall, the exact same problem exists in 02 Dodge Rams (Also a Daimler Chrysler vehicle) but those were recalled, so as it stands we have to spend money out of pocket to fix a problem that should be fixed free as a recall.
They sell an overlay harness which runs 32.00 which is not bad, but if this problem has existed long enough there is melting on the controller, and the connections may be brittle and damged requiring that part be replaced as well, which is 116.00 which IS bad in my opinion.
I know there are enough people with this problem to get a recall, if we all file a complaint.
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #8 of 35 Old 03-07-2006, 06:15 PM
Blake
Redefining body roll
Blake's Avatar
Eh, if someone can convice them to do a blend-door recall, I'm in on it.
My junk is busted, and my girlfriend is cold.
1991 Lexus LS400
Daily Beater
2006 Ford F250 Larait
6.0 Powerstroke | 4x4 | Crew Cab
Blake is offline
post #9 of 35 Old 03-07-2006, 06:28 PM
Briandl
It's possible but not as likely as the blower motor problem.
I don't *think* the blend door problem affects defrosting the window, it might possibly cause that problem for the side windows but I doubt they do a recall for that.
Briandl is offline
post #10 of 35 Old 03-08-2006, 12:11 PM
10achik
I ate what?
10achik's Avatar
Give me the site, and I'm in, I delt with that problem for about a year, before I finally got sick of it and fixed mine.
Ken
2006 Pontiac G6 GTP
10achik is offline
post #11 of 35 Old 06-27-2006, 09:28 PM
Mike200
Just wanted to write in & say I also had this problem with an '04 WJ, and this post helped me fix it. Thanks 10achik!
Two seconds after I started the engine today, the blower stopped working. Never had a problem before (aside from the normal odd sounds the auto-climate control likes to make... different story). It wasn't intermittent, it was totally dead. The wire/ connector into the resistor pack didn't seem melted, and wiggling it around made it work again. More wiggling can also make it stop working -- so hopefully it'll stay put.
Seems like a dumb problem. Minus one point for Jeep...
-Mike
O | | | | | | | O
Mike200 is offline
post #12 of 35 Old 06-27-2006, 09:32 PM
10achik
I ate what?
10achik's Avatar
Thanks, there's another thread I did for the fix. search for resistor pack, I cut the plug, extended the wires and soldered them directly to the reisitor pack board and used heat shrink tubing to keep it from touching...problem solved
Let me know if you can't find it and I will try to look it up four you.
Ken
2006 Pontiac G6 GTP
10achik is offline
post #13 of 35 Old 07-12-2006, 11:54 AM
rflem550
Thanks for all your info. I took my resistor pack off last night, but wasn't able to get the wires disconnected so I could see them. I will probabaly try again tonight.
I put it back on and if I just wiggle the pack or the wires slightly it will make the fan turn off or on, so I feel certain the issue is with the connection.
What do I need to look for once I get the wires disconnected from the pack? Can you find your post about soldering them directly to the pack? I haven't been able to locate it.
Thanks again.
rflem550 is offline
post #14 of 35 Old 07-12-2006, 12:43 PM
rflem550
Nevermind. I found the thread. Good stuff.
http://www.jeepsunlimited.com/forums...d.php?t=678590
It's hot out. Looks like I've got a little project to work on.
rflem550 is offline
post #15 of 35 Old 07-12-2006, 01:40 PM
Jack99WJ
2013 WK
this is same debacle i have had with my 99....i replaced the resistor pack about a year ago only to have it stop working again about 2 months ago. This time the plug had fused itself to the resistor pack.. so as mentioned by an earlier post i just hard wired the wires to the resistor pack and it has worked just fine since. hopefully my ghetto wiring will hold.....
Jack99WJ is offline
'06 Commander climate control blower fan speed switch only works on 'Highest' setting rogerhop WK Grand Cherokee & XK Commander Forum 1 04-11-2009 05:29 PM
Auto Climate Control code 16 weird blower problem.. Dillonzj ZJ Grand Cherokee Forum 3 08-29-2008 09:09 AM
Climate control not working babuajay WK Grand Cherokee & XK Commander Forum 3 06-17-2008 10:48 AM
Dual Climate Control not working nationm ZJ Grand Cherokee Forum 5 11-22-2006 11:36 AM
Climate control not working on passenger side jeepfix ZJ Grand Cherokee Forum 6 11-07-2006 08:58 AM
