climate control - JeepForum.com
post #1 of 6 Old 07-11-2011, 08:02 PM Thread Starter
Freestyle713
1994 ZJ
climate control
ive been using my a/c more often since i got it recharged, and i noticed the direction of the air that comes out of the vents switches between the windshield defrost and whatever other setting it may be set on at the time. anybody ever have this problem?
Freestyle713 is offline
post #2 of 6 Old 07-11-2011, 10:38 PM
JS97ZJ
Check all of your vacuum lines including the vacuum canister. When you accelerate, the throttle plate opens decreasing vacuum. The canister acts as a reserve for holding the blending doors and operating the cruise control system. Also check the brake booster. If that's defective you'll get a hissing noise when the pedal is depressed and the pedal might slowly fade when your stopped at a light. (the booster is probably not the fault)
JS97ZJ is offline
post #3 of 6 Old 07-11-2011, 10:58 PM
KJK
You have a faulty check valve in the vacuum line between the engine and the firewall.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #4 of 6 Old 07-12-2011, 06:41 AM Thread Starter
Freestyle713
1994 ZJ
is this problem easy to fix? how do i go about checking the vaccum canister? and where would i find it?
post #5 of 6 Old 07-12-2011, 07:41 AM
KJK
Check out this technical service bulletin.
KJK is offline
post #6 of 6 Old 07-12-2011, 11:24 AM
JS97ZJ
It's located under the battery tray.
JS97ZJ is offline
96 GC Climate Control se-okla.shooter ZJ Grand Cherokee Forum 0 11-17-2009 10:36 PM
AC standard control UPGRADE to Climate control ? eschapiro ZJ Grand Cherokee Forum 1 01-24-2007 09:26 AM
Climate control Jan ZJ Grand Cherokee Forum 2 01-15-2006 11:48 AM
swaping laredo climate control w/ Limited digital control atlien928 ZJ Grand Cherokee Forum 7 12-28-2003 04:51 AM
Climate Control KeNTeChNiCaL ZJ Grand Cherokee Forum 0 01-08-2003 12:26 AM
