Quantcast clicking when in 4wd *video* - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > clicking when in 4wd *video*
Old 11-20-2009, 11:26 AM   #1
pulsepb
when i engage 4wd high or low i sometimes get this light rythmic clicking or pinging sound. it sounds like if you were to lightly tap a screw driver on a hollow driveshaft. it sounds like its coming from the center or front.
you can hear it here in this video between the groans of mild flex
http://www.youtube.com/watch?v=p5Ddq7lOX8w
2000 wj 4.0
pulsepb is offline   Reply With Quote
Old 11-20-2009, 11:40 AM   #2
(OllllO)
Vid didn't work. I'm interested in hearing though, sounds like what mine is doing.
(OllllO) is offline   Reply With Quote
Old 11-20-2009, 06:36 PM   #3
sandman
just a shot in the dark but it could be a bad u-joint or CV drive shaft.
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Old 11-20-2009, 06:41 PM   #4
baxy
CV joint but take off the front drive shaft and check it closely first
baxy is offline   Reply With Quote
Old 11-20-2009, 06:47 PM   #5
ZJ5point2GCL
mine sounded like that until my cv exploded
ZJ5point2GCL is offline   Reply With Quote
Old 11-20-2009, 08:13 PM   #6
oviedojeeper
agreed...CV joint
oviedojeeper is offline   Reply With Quote
Old 11-20-2009, 08:18 PM   #7
Aureliametal
Thats kind of what the ZJ I just bought was doing yesterday and today the Transfer case is toast.
1996 Jeep Grand Cherokee Laredo 4.0 4X4
Aureliametal is offline   Reply With Quote
Old 11-20-2009, 09:38 PM   #8
peicherokee
cv or u joint i would say mine did the same eventually it will be bad all the time
THE MORE MUD THE BETTER
PEI JEEPERS MEMBER
peicherokee is offline   Reply With Quote
Old 11-21-2009, 01:43 AM   #9
ronsaun
2003 WJ
has it been happening since youve owned it? if so is it possible you have aussie lockers? they click when engaged.
ronsaun is offline   Reply With Quote
Old 11-21-2009, 03:33 AM   #10
sandman
^^^ no they click when disengaged.
1993 Jeep ZJ. 4.0
Old 11-21-2009, 03:17 PM   #11
pulsepb
ive owned it for a few years, its a recent thing.
Ive been real busy and havent gotten a chance to get under it. So you guys think its front driveshaft cv? also does that mean total driveshaft replacement or cant the cv be swapped? also it only does it in 4wd if it were the driveshaft wouldnt it do it all the time? i read somewhere it could be a worn transfer case chain. any thoughts?
no aussie locker btw
Old 11-21-2009, 08:15 PM   #12
sandman
yep, whole new DS.
1993 Jeep ZJ. 4.0
Old 11-22-2009, 12:55 PM   #13
pulsepb
Originally Posted by sandman View Post
yep, whole new DS.
I'm out of town and it's back home so I can't check it out but if it was driveshaft wouldn't it do it all the time and not just in 4wd since the driveshaft always spins. Also if it is ds what is the cause? Wear?
Old 11-22-2009, 04:23 PM   #14
JrMechanic
Transfer Case Guru
JrMechanic's Avatar
Either the front CV shaft or the transfer case chain is slipping.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
http://www.jeepforum.com/forum/f13/np249-np231-np242-swap-information-updated-685644/
JrMechanic is offline   Reply With Quote
Glock Forum
