Clicking noise - 96 ZJ 4.0 - JeepForum.com
post #1 of 6 Old 09-01-2012, 09:25 AM Thread Starter
JoeZedJ
Hey guys, so I have been stumped and confused by this one for a few weeks now. I have browsed a lot of forums and posts but can't seem to find anyone with a solid "yes this fixed the problem". I get a lot of "its probably ..." or "your blah is trashed". Anyways, here goes...
I got a 96 ZJ 4.0 (non-CV front end, u joints). No lift etc, just a bone-stocker. When there is forward/reverse momentum and I am making sharp or slightly sharp turns I am feeling a constant "click" sound from the front end. Its louder and more defined when I am making left hand turns. The clicks never happen when I am stopped or with wheels off. This leading me to a bearing/hub assembly issue or loose suspension components. I have read somewhere that the caliper might come loose? Not sure if that is true or not or how to exactly check for that. When my wheel is off the hub etc seem loose but that's because my wheel is off, otherwise feels just fine to me.
I crawled underneath and put my hands on pretty much everything and checked for play. Nothing out of the ordinary.
-U joints all around
-Track bar
-Shocks/coil springs
I can take/post more photos if it will help, just let me know
JoeZedJ is offline
post #2 of 6 Old 09-01-2012, 09:29 AM
PolkaPower
Sway bar endlinks may be worn out. For the brakes just check that both caliper bolts are still there. I lost one and it was probably months before I noticed it.
PolkaPower is offline
post #3 of 6 Old 09-01-2012, 09:31 AM Thread Starter
JoeZedJ
Thanks Polka, I'll check that out, and take a few photos if there is any in question. I assume if they are slightly cracked/dry-rot, should just replace right?
-Joe
'96 ZJ 4.0 Laredo
JoeZedJ is offline
post #4 of 6 Old 09-01-2012, 09:43 AM Thread Starter
JoeZedJ
...also
Also I forgot to note that when I hit bumps I hear a similar "clicking" noise, although I don't hear it as loudly as I do when I turn. Sounds like a metal-metal click.
-Joe
'96 ZJ 4.0 Laredo
JoeZedJ is offline
post #5 of 6 Old 09-01-2012, 01:05 PM
ZJ_flexxxer
1994 ZJ
could be an axle u-joint or front driveshaft u-joint. but to me sounds like wheel bearing/hub assembly. my hub assembly's started off making a clicking/ticking noise when they were going bad and turned into small popping sound.
MY OTHER TOOLBOX IS A JEEP
94 ZJ Laredo--lifted 4.5", rocker rails, front end/t-case/gas tank skids, tube doors, wj knuckle/brake swap, soft 8's, 32x10.50 tsl's
87 MJ Comanche--zj d44 rear w/ disc brakes, wj knuckles/brakes w/ drilled & slotted rotors,6" lift in progress
90 XJ Laredo--D.D., satin black paint job, 15" ecco's, the redheaded step child of my jeeps
87 XJ Wagoneer--R.I.P. =(
ZJ_flexxxer is offline
post #6 of 6 Old 09-27-2012, 10:42 PM Thread Starter
JoeZedJ
BUMP! Hubs/Bearings and U joints
Ok, so I am doing the hubs/bearing and front axle u-joints this weekend. I will take photos and respond with my findings.
Also, I took a couple quick photos when I had the wheel off the other day. Any other ideas?
Thanks!
-Joe
'96 ZJ 4.0 Laredo
JoeZedJ is offline
clicking , end , front , jeep , zj
Clicking noise Victor9 WK Grand Cherokee & XK Commander Forum 10 08-04-2012 02:55 PM
Clicking noise kernop ZJ Grand Cherokee Forum 2 06-12-2012 01:35 PM
Clicking noise under the dash justinmiller930 WK Grand Cherokee & XK Commander Forum 2 06-10-2011 05:08 AM
Clicking noise aznativemike ZJ Grand Cherokee Forum 6 05-18-2009 07:19 PM
clicking noise chrisstromberg ZJ Grand Cherokee Forum 3 12-16-2007 05:34 PM
