Clicking Noise - JeepForum.com
post #1 of 19 Old 11-10-2013, 07:56 PM Thread Starter
odidipissuoff
Clicking Noise
Hello fellas,
I have searched and searched and can't seem to find the answers that I believe fit my situation.
I have been experiencing what I would call a clicking sound coming from what I believe is the front right (passenger side) of my ZJ. I previously thought it was the ball joints, so this weekend I changed both the upper and lower ball joints on both sides.
I replaced the CV boot on the driver side, there still seemed to be plenty of grease packed in the CV joint.
After putting it back together and the test drive I am still hearing the clicking noise and still seems to be coming from the passenger side. With the research I have done I have heard that it could be
pinion
axle bearings
CV joint
control arms
linkage bushings
I am wondering if anyone has had this problem and what they did to fix it?
odidipissuoff is offline
post #2 of 19 Old 11-10-2013, 08:22 PM
roadcruzer
Originally Posted by odidipissuoff View Post
Hello fellas,
pinion
axle bearings
CV joint
control arms
linkage bushings
Does the noise get worse when turning? You say you checked the CV for grease but usually clicking noises like that is from a bad axle u joint. Did you check for play in your axle u joints?
roadcruzer is offline
post #3 of 19 Old 11-10-2013, 08:28 PM Thread Starter
odidipissuoff
The CV joint I checked was the driver side one, the boot for the passenger side joint looked to be intact and I did not see any grease leakage. So I am unsure as to the exact condition of the CV joint on the passenger side. It does get worse/louder while turning left or going around a left hand curve.
I also have not been able to check the axle U joints either.
post #4 of 19 Old 11-12-2013, 01:07 AM
JasonStebbins
If your description of clicking is anything like mine, it's the CV axle. The boot can look fine but that tells you nothing about the condition of the rest of the axle. Especially if it's old and original.
So do you have CV axles or U-joint axles? Or did you mean drive shaft U-joints?
Poop
JasonStebbins is offline
post #5 of 19 Old 11-12-2013, 02:47 AM
Pugulis
Why did you replace the ball joints? Unless they failed a wiggle test, that was a waist. Sorry. Then you went through the effort to replace the cv boot on the drivers side, but didn't mention the passenger side where the noise was coming from. And the only thing you did was check and see how much grease was inside? That's not even close to a proper test. Sorry again. Is the noise a constant clicking? Or does it click when you make turns? Or is it random clicking. The CV axle only cost 50 bucks. Without knowing the complete problem, I'd say replace it and your problem will go away.
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
post #6 of 19 Old 11-12-2013, 06:44 AM Thread Starter
odidipissuoff
I have CV axels. Something that might help, when I have the vehicle in reverse (maybe other gears as well) and just idling with my foot on the break I can hear the same clicking noise. Would the CV still make noise without moving?
post #7 of 19 Old 11-12-2013, 01:35 PM
ROFLwaffles
I had the same thing. Turned out to be the sway bar end links. Do you have excessive body roll when turning right?
ROFLwaffles is offline
post #8 of 19 Old 11-12-2013, 01:48 PM
JasonStebbins
No.
Now I'm really confused. Are you sure clicking is the best description of what you're hearing? Without moving, the noise can really only be the motor or exhaust system.
Poop
post #9 of 19 Old 11-12-2013, 02:13 PM Thread Starter
odidipissuoff
Originally Posted by JasonStebbins View Post
No.
To be honest clicking is the best I can describe it. It's not the exhaust. It only does the noise while in reverse with the foot on the break, not any of the gear.
post #10 of 19 Old 11-12-2013, 02:16 PM
JasonStebbins
Is it a constant clicking? It might be time for a video, because I have no idea what could be clicking while idling.
The only thing I can think of is the evap solenoid cycling or lifter tick?
Poop
post #11 of 19 Old 11-12-2013, 03:02 PM Thread Starter
odidipissuoff
It seems to very with speed & acceleration. I'll take a video tonight or tomorrow
post #12 of 19 Old 11-12-2013, 03:14 PM
JasonStebbins
Is it the exact same clicking sound while driving and when your in reverse with your foot on the brake?
CV axles are the only thing that "click" when they are bad. Otherwise you're looking at the tire rubbing on something.
If something is literally broken in two, it could be hitting against itself or something else?
Post a video, you're killing me.
Poop
post #13 of 19 Old 11-12-2013, 03:21 PM Thread Starter
odidipissuoff
It's killing me as well, hearing it while I drive makes my ears want to bleed.
post #14 of 19 Old 11-12-2013, 04:57 PM
rlcii77
Is it possible that it could be an extremely bad motor mount causing the cooling fan to hit the shroud... Or, maybe something rattling against something.... I'd have to rule out the CV due to the absence of the noise when not in motion... I'd get an assistant to hold the brake while in reverse and look up under the front of the Jeep while it's making the noise... Good luck...
'72 CJ5 Ren
'91 XJ, '96 XJ, '98 XJ
'94 ZJ, '96 Orvis ZJ
'98 Platinum 5.9, '98 Slate 5.9 (DD)
rlcii77 is offline
post #15 of 19 Old 11-12-2013, 05:00 PM Thread Starter
odidipissuoff
I guess I have a where's Waldo hunt to participate in this weekend, I will keep you informed as to what I find. I tried to take a video, but my phone wouldn't pick the sound up.
