"Click" When Turning? - JeepForum.com
post #1 of 8 Old 05-12-2014, 07:16 AM Thread Starter
Gibby913
My jeep started making a loud *** click from my drivers side wheel when turning. Whats broken? CV maybe?
-=Gibby=-
1997 Jeep Grand Cherokee 4.0L I-6 150,600
Gibby913 is offline
post #2 of 8 Old 05-12-2014, 07:20 AM
Timo_90xj
Timo_90xj's Avatar
Is it constant clicking, relative to wheel speed? Quiet (or almost quiet) when going straight, clicking only when turning?
If so, sounds a lot like worn CV- joint or u-joint (whichever your ZJ has).
***Under construction***
Timo_90xj is offline
post #3 of 8 Old 05-12-2014, 07:42 AM Thread Starter
Gibby913
It's only when turning at a decent speed. I don't here anything when driving straight......What does that mean?
-=Gibby=-
Gibby913 is offline
post #4 of 8 Old 05-12-2014, 07:44 AM Thread Starter
Gibby913
It has been squealing when turning for a year or so........does that mean anything to you? Also for the last month when turning hard I could hear a hard clunk every now and then.....never was able to pinpoint its location or cause tho.
-=Gibby=-
Gibby913 is offline
post #5 of 8 Old 05-12-2014, 01:56 PM
ikidd
If you can get someone to saw the wheel back and forth while you listen,you might find it. I had the track bar bushing floating and it would clunk hard once each time i turned the wheel. Do this on a loose surface or you'll damage the tires.
squealing is probably low fluid in PS pump, or the pump has issues.
1998 ZJ 5.9 - 4", NP242
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
1994 ZJ 4.0 "Rammy" RIP
ikidd is offline
post #6 of 8 Old 05-12-2014, 02:40 PM
Timo_90xj
Timo_90xj's Avatar
If it's a single clunk/ creek/ click and is not consistent with wheelspeed, it is not your CV-/ or U-joints. A single creak or click is a loose suspension component, if you mostly get it when steering it's most likely a trackbar issue. That being said, it can be pretty much any suspension- related component.
If you get a moaning/ whining when turning the steering wheel (especially if/ when you turn it to full lock), it's your power steering pump.
post #7 of 8 Old 05-12-2014, 04:12 PM
supermac88
supermac88's Avatar
If it's whining, and you fell a clunk in the steering when turning a certain direction but it's fine going straight check your hub/ wheel bearings.
Sent from my job using Jeep Forum
1998 ZJ 4.0 Laredo SE 3.5" RC 255/75R17's on JK's Ford 8.8
supermac88 is offline
post #8 of 8 Old 05-12-2014, 05:34 PM
ZJNewbi3
I have a clunk noise sometimes when making a turn. Rare though. I think I need new track bar bushings to solve my problem.
The wine is defiantly the power steering pump.
Just trying to keep her goin'!!
ZJNewbi3 is offline
