Quantcast Clear Headlights! *Big Pic Warning* - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Clear Headlights! *Big Pic Warning*
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 03-10-2006, 04:35 PM   #1
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
After drooling over several newer WJ's like Arlos, I noticed how horrible my pitted light housings were. Then I was inspired by this post and took it on for myself.
http://jeepforum.com/forum/showthread.php?t=239104&highlight=grit+2000
It was simple to do. I did not wet sand but used 1000 to grind down pits, then 2000 to soften it up, and then used 4 coats of Plastix.
It came out great.
Tips:
Try to get the majority of the scratches out with the 1000 grit snadpaper. Don't be afriad to sand the hell out of it. It will only take more time going little by little.
It's going to look really cloudy, almost like you ruined it. Do not stop. Sand the hell out of it.
Wet sanding may be safer, keeping the dust down, but dry sanding allowed me to see the remaining pits. (they were filled with light dust.)
Remember that it is much easier to do alot of work with the sand paper than spending 4 hours polishing with plastix.
SUPPLIES:
OLD PICS:
(Lights on)
Wicked Shiny (Pics don't show as much clarity as I thought they would, there even better than this in real life)
WALTER
walter_da_jpr is offline   Reply With Quote
Old 03-10-2006, 04:37 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Looks a lot better like that
ArloGuthroJeep is offline   Reply With Quote
Old 03-10-2006, 04:39 PM   #3
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
That looks great.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links: Kevin (AKA KOR) for ZJ & WJ stuff,
Kolak for performance stuff. I6 performance info at Dino's jeep 4.0 performance site
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline   Reply With Quote
Old 03-10-2006, 04:39 PM   #4
walter_da_jpr
I am jealous of your color and overall appearance, but now at least I can say, I too have shiny lights.
WALTER
Old 03-10-2006, 04:40 PM   #5
Varkyl
No where near stock
Varkyl's Avatar
very nicely done!
did you use a power buffer or just elbow grease?
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline   Reply With Quote
Old 03-10-2006, 04:46 PM   #6
grandCherokee06
Where did you get the 200 grit and plastx ? I havnt found 2000 grit yet. It was hard enough trying to find 1000.
[COLOR="Red"] [ l_,{____},
[---L –[/COLOR]0[COLOR="Silver"]lllllll[/COLOR]0[COLOR="Red"]-[/COLOR]
()_) ()_)--[COLOR="Red"]o[/COLOR]-)_)
[B][I][U]1993 Jeep Grand Cherokee[/U][/I][/B] [B][I][U]5.2L ~ V8[/U][/I][/B]
grandCherokee06 is offline   Reply With Quote
Old 03-10-2006, 04:47 PM   #7
walter_da_jpr
Good old fashion elbow grease.
WALTER
Old 03-10-2006, 04:49 PM   #8
walter_da_jpr
It took me a while too. Your best bet is an auto parts store like Auto Zone. 1000 and 2000 grit isn't used for much other than cars.
WALTER
Old 03-11-2006, 02:45 PM   #9
grandCherokee06
Well I found some 2000 grit today. I also picked up a different bottle of wax. I got some of the Meguiars PlastX like Walter_da_jpr got. I used the exact same things. Heres a before and after picture. *Note: It looks alot better in person*
BEFORE:
http://img133.imageshack.us/img133/8263/167xd.jpg
AFTER:
http://img133.imageshack.us/img133/827/picture0020qr.jpg
http://img52.imageshack.us/img52/1497/picture0037kh.jpg
Old 03-11-2006, 07:42 PM   #10
walter_da_jpr
BEFORE:
AFTER:
UGH those were gross.
They look great now
WALTER
Old 03-11-2006, 10:12 PM   #11
PlatinumZJ
PlatinumZJ's Avatar
here you go
Headlights before
and after
Doug
Old 01-15-2007, 05:10 PM   #12
94XJMadness
Awesome job Dubya, too bad you now have one new head light and the one old one. stupid expedition driving foriegners
[_] ||||||| [_]
94XJMadness is offline   Reply With Quote
Old 01-15-2007, 06:37 PM   #13
turk
You guys really want 2000 grit sandpaper? How about 12000!!! I deal with acrylic a lot and there is only one real good kit I would recommend and if you want, you can get up to 12000 grit. It is more like leather. Anyway, the product is called micro-mesh. Do a search on google and you should find it. Just thought I would chime in with that. Sorry not exactly on topic. here is the link to one source. Happy polishing!!
http://www.sisweb.com/micromesh/conversion.htm
Turk
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline   Reply With Quote
Old 01-15-2007, 07:13 PM   #14
gunthagunth
Nice old thread BTT
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Claytons/JKS Control arms out back/Addco's/RE brake lines/35"TSL SSR's on 5.9rims/Currie steering/K&N/JKS rear trackbar/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/D30lockrite D44a
gunthagunth is offline   Reply With Quote
Old 01-15-2007, 11:51 PM   #15
Redbob
Yeah, good thread!
I might add that wet sanding keeps the sandpaper from clogging.
Also that all the really good grades of sandpaper are found at your automotive paint supply place, like DuPont for instance.
I might start with something more like 400 or 60 for deep pits, and work up to avoid spending huge amounts of time on the job.
I've used the same technique on the plastic windows in a Wrangler soft top.
Redbob is offline   Reply With Quote
Glock Forum
