Cleaning mating surface/ soaking plenum - JeepForum.com
post #1 of 8 Old 04-13-2013, 06:09 PM Thread Starter
sevenscrew
What did u guys do to clean ur plenums?
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #2 of 8 Old 04-13-2013, 07:02 PM Thread Starter
sevenscrew
And should I add a thin film of ultra black on both sides of the manifold gasketss ?
2016 2DR JK
post #3 of 8 Old 04-13-2013, 07:45 PM
sebian
I used brake cleaner for a while, then switched to mureatic acid. Let the plate and intake soak for about an hour each, then scrubbed away what was left. As a word of caution, you will want to use gloves and goggles to protect yourself a little bit.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #4 of 8 Old 04-13-2013, 09:17 PM
PolkaPower
I just used a dab of RTV on the manifold gaskets to keep them in place.
PolkaPower is offline
post #5 of 8 Old 04-14-2013, 01:01 AM Thread Starter
sevenscrew
Is there anything I can get easily that I can soak it in? I have super clean degreaser (spray) which takes off the oil very easy just wipe and it comes off but it says prolonged use on aluminum isn't good so I don't want to soak it .
Do I have to soak it? I have the inside of the intake very clean. Just the chambers (all) have oily throughout them I think
2016 2DR JK
post #6 of 8 Old 04-14-2013, 06:28 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Easy Off oven cleaner....Spray on, wipe off. Don't let it soak while you go on a beer run.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 8 Old 04-14-2013, 06:44 AM
Maine1994ZJ
Hunter
Speaking of Easy Off..
Easy Off also works great to remove the "chrome" from plastic parts...
Again, don't go for a beer run.
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #8 of 8 Old 04-14-2013, 07:12 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I use RTV around the coolant ports. One or two of the manifold bolts go into the water jacket so use thread sealer.
HighLonesome is offline
