"Clack" noise when turning right - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > "Clack" noise when turning right
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 03-29-2014, 12:27 PM   #1
stevekris73
Got this "Clack" (once) sound when turning relatively hard right. Guess something is worn. Whats the likely culprit here? Changed complete cv joints, bearings and ball bearings 6 months ago on both sides, so in theory it shouldn't be one of those.
Anyone got a tip?
Thanks in advance for any input!
stevekris73 is offline   Reply With Quote
Unread 03-29-2014, 12:34 PM   #2
JasonStebbins
Obv
JasonStebbins's Avatar
Clack is a new one.
Track bar would be my first guess followed by control arm bushings, tie rod ends or ball joints.
Common ZJ problems and how to fix them by JasonStebbins
http://www.jeepforum.com/forum/f13/c...x-them-1432264
12 things to do when your ZJ stalls by ZeeJay1997
http://www.jeepforum.com/forum/f13/1...talls-1407423/
JasonStebbins is offline   Reply With Quote
Unread 03-29-2014, 12:58 PM   #3
Alexandru999
mine too does a "clack" when turning 90 degrees right on idle since im guessiing the wheels have more force against them when turning idle vs. turning in drive mode, had a friend move the wheel for me, i saw a loose spot in the track bar under passenger side, just inspect it and most probably ull see it
Alexandru999 is offline   Reply With Quote
Unread 03-29-2014, 12:59 PM   #4
rstantoniii
Check your tie rod ends or ball joints for play.
rstantoniii is offline   Reply With Quote
Unread 03-29-2014, 01:12 PM   #5
stevekris73
Hehe, sorry. "Clack" was the best description that came to mind to describe the sound
Changed the ball joints too along with the cv and front bearings.
Thanks for tips, always somehow find it motivating to track the problem on the Jeepforum before getting crawling the garage floor :-)
Didn't consider the tie rods, but isn't worn tierods likely to be heard every time when going over e.g. a series of bumps? Seem to remember that on my other cars, this has always been the case.
Guess there is no other way than take out a six-pack and do some garage time :-)
Thanks for the tips, guys.
Unread 03-29-2014, 01:39 PM   #6
tucsonzj
i wish i had a garage haha
[COLOR="Purple"]1995 ZJ Limited-3.5" Rubicon Express, 33x12.5s and some other stuff. Maybe half of it works, but it stops so that helps.
[/COLOR]
Build thread [URL="http://www.jeepforum.com/forum/f197/tjs-zj-build-1518251/"][COLOR="Yellow"]Here[/COLOR][/URL]
[QUOTE=riot1987;15573985] I learned to tuck my stick....[/QUOTE]
[QUOTE=kg6mov;19913617]Yeh, washing it inside and out is on my to-do, eventually, maybe, if I have time, OOOH angle grinder.[/QUOTE]
RIP Ratmonkey-5/27/13. You will be missed.
tucsonzj is offline   Reply With Quote
Unread 03-29-2014, 02:40 PM   #7
dusterdude
Me too,mine is full of motorcycles lol
dusterdude is offline   Reply With Quote
Unread 03-29-2014, 04:25 PM   #8
tucsonzj
another problem I wish I had haha
[/COLOR]
Unread 03-29-2014, 04:37 PM   #9
jimbone007
me too haha
jimbone007 is offline   Reply With Quote
Unread 03-30-2014, 02:05 PM   #10
stevekris73
Found the problem...Broken stabilizer bar. Didn't see it at first since it looked normal when at standstill. Closer inspection - shaft broken clean off
Unread 03-30-2014, 02:10 PM   #11
MurdaJs
Damn I was gonna guess sway bar link
Built one piece at a time, and it cost me many dimes
MurdaJs is offline   Reply With Quote
