Chronic fuse blowing..But Why???Help please - JeepForum.com
post #1 of 3 Old 06-26-2003, 03:54 PM Thread Starter
Kneeland24
A fuse has repeatedly blown under the hood. The fuse seems to be for the automatic shutdown relay, powertrain control module. If anyone has any idea what the problem could be and any advice on how to fix it, it would be greatly appreciated. Thank you, Greg.
Kneeland24 is offline
post #2 of 3 Old 06-27-2003, 08:28 PM
RockPaws
RockPaws's Avatar
Wiring problems are the hardest to repair. If its blowing the fuse, its probably a shorted wire. Follow the wire if possible. Or check the wire looms in that area, for rubbing, chafing, or maybe it pinched by something that was bolted down or clamped. It takes some time to find these kind of problems.
In the PDC is where the 20 amp fuse keeps blowing (I assume) This fuse provides pwr to the B(+) Fused to the Power Train Control Module (PCM). The ASD (Auto shut dn Relay) is also in this circuit. This provides a positive indication to the PCM when the ASD is activated. This will also generate a fault code.
So it looks like the short is between the fuse, the ASD, and the PCM.
Now you just need to find it. Its probably a intermittent problem and not a hard fault or direct short. Or maybe it is. You will just need to follow the wires and or loom and look for problems and repair the wire. It may be red wire witha yellow tracer.
Good luck.
Frank
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #3 of 3 Old 07-01-2003, 07:50 AM Thread Starter
Kneeland24
thanks man. It ended up being the powertrain control module and we could find this by following the red wire with yellow strip. The pcm shorted out. Pretty penny but at least she's running now..
Blowing fuse 97jeepgcl ZJ Grand Cherokee Forum 5 12-20-2009 05:29 PM
4.0 keeps blowing fuse 18??? vp6799 ZJ Grand Cherokee Forum 8 11-06-2008 05:04 PM
ASD(?) Fuse keeps blowing, 98 ZJ won't run mgw1971 ZJ Grand Cherokee Forum 9 05-14-2008 07:27 PM
Blowing Fuse #8 IN99WJ ZJ Grand Cherokee Forum 7 09-03-2007 02:02 PM
94 GC Ltd. Fuse 12 Keeps Blowing philcourtney ZJ Grand Cherokee Forum 1 11-26-2004 12:09 PM
