Chirping noise - JeepForum.com
post #1 of 2 Old 09-19-2013, 04:15 PM Thread Starter
jeepycreepy96
Chirping noise
Hey guys so in my 96 there's a weird chirping noise at low speed up to about 45 that won't go away. I just replaced the front pads and I haven't looked at the the rears yet. it sounds as if it would chirp at a certain point then the wheels would rotate and chirp like if the rotor is has a high point. Can't tell
jeepycreepy96 is offline
post #2 of 2 Old 09-20-2013, 01:47 AM
jabba974
Check the brake pads and see if the wear indicator is bent to close to the rotor..or check the clearance on the backing plate...
jabba974 is offline
