Cherokee only sometimes starts then dies. Code 13. - JeepForum.com
post #1 of 25 Old 08-19-2013, 06:24 PM Thread Starter
Trick440
1994 ZJ
My GC seems like it has an electrical issue. Out wheeling last weekend I went in a medium deep mud/water hole. It died, few seconds later it started up but died again.
So if you try and start it, it will only sometimes (rarely) start up and then die shortly after. Even if I hold the rpms high it just suddenly dies and dies like someone flipped a switch. When it is running it seems to run kinda bad.
I swapped crank & cam sensors, cap, rotor, plug wires, ect. Nothing seemed to help.
I did the key on and off trick to pull a 13 engine code.
Could a map or O2 sensor cause this problem.? Any ideas?
Trick440 is offline
post #2 of 25 Old 08-19-2013, 07:21 PM
ZeeJay1997
year?
ZeeJay1997 is offline
post #3 of 25 Old 08-19-2013, 07:34 PM
riot1987
I dont believe a bad map or o2 sensor wouldn't allow it to start. I think it would just throw a light
Build thread^^
riot1987 is offline
post #4 of 25 Old 08-20-2013, 06:54 AM Thread Starter
Trick440
1994 ZJ
its a 94
Trick440 is offline
post #5 of 25 Old 08-20-2013, 02:27 PM
dellis
2005 WK
Yes, I don't think that your MAP is the source of your problem ... given that this happened when you went into mud/water, I have to think that this is the first place to look (and not electrical). For example, have you gone through and checked your air intake, including the possibility that your air filter is clogged with mud or other debris?
dellis is offline
post #6 of 25 Old 08-20-2013, 04:00 PM Thread Starter
Trick440
1994 ZJ
Yup no mud or water intake.
This problem happened a few weeks ago too except wouldn't start at all. I went in a few puddles no problem, then a few minutes later cruising down the trail it just shuts off. I let it sit in my backyard for a few weeks and it started up and ran. It ran it all day with no issues. Next day is what my original post describes.
I'm starting to think my computer is failing. One weird thing I do not know if its related is I have been hearing electrical crackling passenger side front speaker, atleast I thought it was coming from the speaker. I noticed it both times the jeep died.
I'm going to go through the list ZeeJay1997 has in his sig. See if anything helps. This jeep is my toy so I'm not in too much of a hurry to fix it.
Trick440 is offline
post #7 of 25 Old 08-21-2013, 12:00 PM
Oldfrog
2007 WK
"One weird thing I do not know if its related is I have been hearing electrical crackling passenger side front speaker, atleast I thought it was coming from the speaker. I noticed it both times the jeep died."
This might or might not be a clue. Check the ground under the coil if you have a 4.0 engine.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #8 of 25 Old 08-31-2013, 04:02 AM
Speedymcracer01
Your model jeep has been known for bad wiring boots on the computer they become loose sometimes wiggling the wiring harness will get them to fire others have to replace the wiring boots
Speedymcracer01 is offline
post #9 of 25 Old 09-12-2013, 08:40 PM Thread Starter
Trick440
1994 ZJ
Update:
Code 13 is fixed. Vacuum line was unplugged. We must of bumped it off while we were working on it.
The no start and suddenly lose spark is still an issue.
I did Zeejays dirty dozen and everything checked out. All connections look good. Full tune up, cap, rotor, wires & plugs. Tested the coil comparing it to 3 other coils and they all tested the same, so i'm saying the coils good.
Now I don't know what to do. I'm thinking this is a computer issue and I would like to test the computer but don't know how.
I also think there are 2 computers, one passanger side firewall near coolant ressy and the other driver side near the airbox. Can someone tell me about each computer.
Trick440 is offline
post #10 of 25 Old 09-13-2013, 03:00 AM
Oldfrog
2007 WK
Have you tested the Crank sensor? Or just replaced it? If replaced, was it a MOPAR sensor?
What about the connectors that would have gotten wet during your mud hole episode? Have you pulled them apart, cleaned them and re-connected them?
Oldfrog is offline
post #11 of 25 Old 09-13-2013, 09:23 AM
zjosh93
The one by the coolant reservoir is the PCM, it controls the engine. The one by the air box is the ABS brake controller. FWIW there's also one above your pedals and a bit toward the door mounted to the inner firewall that controls the transmission if you have the 42RE.
The 93-95 PCMs don't seem to have the bad connector problems that the later ZJs have but they do get bad capacitors which are pretty easy to change. There are a couple write-ups here how to do that.
You should be able to grab a computer at a junkyard to try instead of your original PCM. I ran a 94 computer with a different part number in my 93 while I replaced the capacitors with no issues. Having said that, PCMs rarely go bad.
zjosh93 is offline
post #12 of 25 Old 09-13-2013, 09:53 AM
johns1mj
It looked like we assumed this was a 4.0.
According to your posts you have replaced the crank sensor, tested fuel pressure, performed a tune up, and checked the signal to the coil. Have you tried a spark tester? Do you have injector pulse? Basically it check how far your coil will arc for strength. If you have signal going into the coil but nothing coming out then the coil is bad.
If you have injector pulse attach a test light to battery positive (B+). Back probe the coil negative wire at the coil which is Grey/White. Crank the engine over and the test light should flash on and off. If it flashes, then the coil is likely shorted on the secondary winding. The coil secondary winding should be 11,000 to 15,000 ohms. Replace the coil and the harness per TSB #08-35-93.
johns1mj is offline
post #13 of 25 Old 09-13-2013, 10:28 AM
zjosh93
When my first coil went bad the resistances all checked good but I was having very bad constant misfires. I threw a coil at it and it fixed the issues.
zjosh93 is offline
post #14 of 25 Old 09-13-2013, 09:11 PM Thread Starter
Trick440
1994 ZJ
This is a 4.0. I'm going to get a junkyard computer I think. I have a spare 96 cherokee with a computer if they matched that would be awesome.
Trick440 is offline
post #15 of 25 Old 09-13-2013, 09:35 PM
zjosh93
The 96 PCM is an entirely different beast. You wouldn't even be able to plug it in. The 96 and up have three plugs, the 93-95 have one big plug.
zjosh93 is offline
