checklist of common things that go wrong on wj's. mechanically speaking. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > checklist of common things that go wrong on wj's. mechanically speaking.
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 04-21-2008, 08:05 PM   #1
fivespeedsteed
so i just replaced the fan relay, and am about to replace the fan itself due to them being dead, and it got me wondering what parts on a wj are common to fail. im at 120k and i want this to be a reliable car for me, so like i have done with the mustang, i want to do some preventative maintinance. what else can i go about replacing other than plugs, air filter, ect. thanks for the help.
2007 Ford F150
1990 Mustang GT
fivespeedsteed is offline   Reply With Quote Quick reply to this message
Unread 04-21-2008, 08:13 PM   #2
JeepOrvis97
diff fluids, t-case fluids, etc. search the forum for what types to use and how to do it.
JeepOrvis97 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2008, 08:34 PM   #3
fivespeedsteed
so other than the cooling system stuff, all there is is fluids really?
2007 Ford F150
1990 Mustang GT
Unread 04-21-2008, 08:38 PM   #4
QuadraTokn
1930 WJ
Replace ALL fluids and worn suspension components/bushings.
LIKE US ON FACEBOOK: Valhalla Fabrication
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline   Reply With Quote Quick reply to this message
Unread 04-22-2008, 12:37 AM   #5
fivespeedsteed
and theres nothing else i need to watch out for in the way of parts that break commonly. no tie rods, balljoints, anything? thats kinda reassuring to me becasue im to the point where i have allot of money in my rig as of right now. and its worrying me. my dad and i are worried this thing will never stop breaking. fluids include, and add it for me if i forget any, oil, coolant, brake, trans, tcase, diffs, wiper () right?
2007 Ford F150
1990 Mustang GT
Unread 04-22-2008, 01:00 AM   #6
TRL
Not calling it a car is good preventative maintenance.
Seriously though, the best thing that you can do is change your fluids religiously. From what you have posted in the past, it looks like the PO of your Jeep didn't maintain it as well as they should have, and so I think you can expect your dub to has some problems.
1997 ZJ Laredo. 4.0 I6, 242 TC.
Originally Posted by millhousenator View Post
Jeeps are like boobs, some are big, some are small, some look fake and some look real, but they are still boobs so get the **** over it!
nightcrew #0040
TRL is offline   Reply With Quote Quick reply to this message
Unread 04-22-2008, 01:03 AM   #7
CrazyWalnut13
Is there some sort of kit the comes with all suspension bushings? I known I've seen kits like that for Wranglers.
I'm just wondering because at 129,100 miles and have lots of squeeks and creaks when I go over bumps and around corners.
Where is a good place to get all of these bushings?
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2008, 08:06 AM   #8
fivespeedsteed
doh. i totally did call it a car. i got in the habbit of calling it a truck(stupid, i know) but im out of it. im ashamed of myself. yes the PO did let her get a little bad. ill be much better with fluids and maintanance.
2007 Ford F150
1990 Mustang GT
Unread 04-22-2008, 08:34 AM   #9
gpJeep
replace all the sensors hahah
camshaft crakshaft transmission temp vaccum
map etc as needed or as required
don't worry you'll know
POLISH - CANADIAN ........... JEEP Lovers CLUB
gpJeep is offline   Reply With Quote Quick reply to this message
Unread 04-22-2008, 08:46 AM   #10
mailforjon
2005 WK
check out the maintenance section of wjjeeps.com for some good guidelines for preventive maintenance/fluids/etc.
when it comes to parts that either work correctly or are totally broken (sensors, lights, etc), i usually wait until they are non-functional before replacing them. otherwise, you could end up replacing parts that have years of "life" left in them.
but when it comes to things that slowly degrade over time (fluids, plugs, etc), a little up front maintenance goes a long way.
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline   Reply With Quote Quick reply to this message
Unread 04-22-2008, 10:57 AM   #11
Double E
2000 Laredo V8
Double E's Avatar
Hood struts, radiator, front tweeters, tail light bulbs & housing, door lock actuators and brakes. If you have not had an issue yet, you probably will.
None are terrible or will break the bank but about all can be handled yourself with not much brains. (Ask me how I know)
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 04-22-2008, 11:05 AM   #12
fivespeedsteed
ok good deal. what is it with the brakes again, what years warp rotors worse than others, and what do i need to fix this. calipers from a newer year? or just rotors from a newer year?
2007 Ford F150
1990 Mustang GT
Unread 04-22-2008, 12:13 PM   #13
fivespeedsteed
nevermind i read about the problem and found this http://www.justforjeeps.com/akbrcakit.html
is this the cheapest i can find?
2007 Ford F150
1990 Mustang GT
Unread 04-22-2008, 12:27 PM   #14
tennesseewj
email kolak@aol.com
Most people say he has great prices
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline   Reply With Quote Quick reply to this message
