Check Gauges/ Check Battery - JeepForum.com
post #1 of 8 Old 02-12-2006, 11:51 AM Thread Starter
sunflash2012
I was driving to work in this snow storm this morning and a couple minutes after starting the jeep the check gauges light came on. The display computer showed a check battery and check cables warning. The gauge on the dash was all the way left showing 0. The jeep started right up and seemed to drive fine. One the way home a few hours later there was no light and now warnings at all. I didn't notice the position of the gauge because I was just concerned about getting home in the snow. I was told by a friend that it may be a sign of the alternator going. Is this the likely case or could it be something else. Or just a fluke. Thanks.
Just for more information, the jeep has been sitting in the driveway during the past few weeks while I take the train to work. I have only used it lately to go a couple miles to my other job on the weekends. I drove it around about 20 miles yesterday with now problems.
1998 5.9 Limited (White)
76,200 miles
sunflash2012 is offline
post #2 of 8 Old 02-12-2006, 04:06 PM
02Lightning
I would check your cables for corrosion and check you ground connection to the motor.
2001 Jeep Grand Cherokee Laredo 4.0L NV242LD Transfer Case, 42RE, 119,500 miles
02Lightning is offline
post #3 of 8 Old 02-12-2006, 11:32 PM
97zjjeeper
97zjjeeper's Avatar
i am haveing the same happening on my jeep as yours i put a new belt and am replacing the ALT. monday
its all good then out of the blue the volt drop out flat to 9 and the check battery light turns on, then i shut her off poped the hood and all looked good started it back up and was working just fine its done this to me in 2 days
Tater
BLACK 97 ZJ 4.0L-42re-242-DANA 30/35 (3.73)
MODS) 2in lift-30x9.5x15 BFG A/T-15x8 Pacer Wheels-K&N Intake-1in TB Spacer-40Series Flowmaster-Hi-Flow Cat-JKS Trackbar-Sliderz-BDS adj CA-BDS SS-Cobra19 ULTRA III-FireStick4FT-PA Horn-Hella500 DL-Roof Rack-TC Skid-Gastank Skid
97zjjeeper is offline
post #4 of 8 Old 02-13-2006, 12:23 AM
-Joe-
-Joe-'s Avatar
On some years the voltage regulator is part of the ECM/PCM module (Might also be for yours).. Why on earth jeep put it there instead of on the alternator who knows..
Might want to have your charging system checked before replacing anything.. edit: but then again I guess if you replace the alternator and it still does it, you know its the voltage regulator.. Unless someone knows a way to test this..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 8 Old 02-13-2006, 01:10 AM
97zjjeeper
97zjjeeper's Avatar
well this is the code i got #47 (Battery voltage sense input below target charging during engine operation. Also, no significant change detected in battery voltage during active test of generator output circuit. (voltage too low)
Tater
post #6 of 8 Old 02-13-2006, 01:35 PM
97zjjeeper
97zjjeeper's Avatar
well the new ALT is on and now its a waiting game to see if it happens agin
Tater
post #7 of 8 Old 11-06-2009, 05:12 AM
JoshuaDHarp
I am having this problem this morning. Check battery warning comes on and gauge drops to 0. When I turn it off and put the key to acc it comes up to 9, but as soon as I start it, it drops back to zero. I drove it all the way home yesterday (1 hour). This morning though it didn't make it, I had to buy a battery just to get the thing home.
I have the day off and need to get it fixed, any suggestions? Good ground, corrosion free.
1997 ZJ Laredo-183k 4.0 2" BB 31" BFGooodrich AT 15 in. Cragar Soft 8's Rola Roof Rack Rough Country Shocks
01 WJ-79k, 4.0 Stocker
JoshuaDHarp is offline
post #8 of 8 Old 11-06-2009, 08:47 AM
JoshuaDHarp
Replaced alt. All good.
99 WJ Check Gauges W3MOT ZJ Grand Cherokee Forum 1 01-04-2010 12:52 PM
overheating/check gauges problem?? drob951 ZJ Grand Cherokee Forum 2 06-25-2009 10:47 PM
Check Gauges Light debbie9339 ZJ Grand Cherokee Forum 2 08-21-2007 02:32 PM
Check Gauges Thadopestone ZJ Grand Cherokee Forum 9 03-19-2006 06:37 PM
