Check Engine Procedure 98 ZJ - JeepForum.com
post #1 of 2 Old 07-01-2003, 08:44 AM Thread Starter
wake5150
Guys,
I heard there was a way to turn the ignition on and off and on and off and get some beep or blink codes to tell you WHY the check engine light is on.
Anybody know this procedure?
Second Question: What are the top 3 reasons for a check engine light on a 98 ZJ 5.2L
Chris
wake5150 is offline
post #2 of 2 Old 07-01-2003, 09:41 AM
jeepme79
1. Turn Jeep off.
2. Turn ignition to 'On', then 'Off' three times within 5 seconds, but leaving it 'On' the last time.
3. The check engine light will flash two digit number codes to you, with a one second pause between the two digits, and a two second pause between each different code. A code of 55 marks the end of the error codes.
This is listed out in the Chilton's manual alone with a rough table describing what each code means, and is fairly common for mid 90's and up Chryslers.
2003 Dodge CTD Quad Cab 4x4, 320k miles and counting
Former Jeeps:
98 ZJ Limited, 5.2L, NP242, Jet Stage II (worthless), K&N, 245/75-16 BFG KO's
89 XJ, stock
79 CJ7 - Options included ripped soft top, leaky 4.2L (5qts/week), ripped seats, 33" tires, bondo & gray primer
jeepme79 is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 10:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 09:04 PM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 08:28 AM
Engine Swap Procedure questions freejeep ZJ Grand Cherokee Forum 23 10-20-2006 02:10 PM
