Check engine light and ways to check codes - JeepForum.com
post #1 of 13 Old 07-14-2006, 08:40 PM Thread Starter
cody11ca
Is there a way to check the codes in the computer like you are able to do with a YJ? The reason i asked is my check engine light just came on in my 97 jeep grand cherrokee and it has 149,000 miles on it, ideas?
cody11ca is offline
post #2 of 13 Old 07-14-2006, 08:42 PM
anticrombie
anticrombie's Avatar
Turn the key on then off then on then off like 5 times and the odometer will display any codes.
Charlie
anticrombie is offline
post #3 of 13 Old 07-14-2006, 08:52 PM
husker_zj
does that work for a 93?
Just because I'm workin' on it don't mean I'm fixin' it...
US Navy Jeep Club Hull#43
NEBRASKA JEEP CLUB Member #1
husker_zj is offline
post #4 of 13 Old 07-14-2006, 09:11 PM
rm2001wj
rm2001wj's Avatar
Here's the procedure (doesn't work on '98 models): http://www.zjilla.com/tech_codes.htm.
rm2001wj is offline
post #5 of 13 Old 07-14-2006, 09:15 PM
Meerkat
Yes, it does, except that the codes are read out by the number of flashes by the CEL, rather than by numerical display in the digital odometer.
Wow, we are posting in the future! Not too bad!
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #6 of 13 Old 07-14-2006, 09:51 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Autozone will read the codes for free - I'm sure that PepBoys does it too. Checker does as well. I have had probs in the past pulling codes from 97/98 GCs
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #7 of 13 Old 07-14-2006, 09:51 PM
husker_zj
yea, pretty sweet huh
post #8 of 13 Old 07-14-2006, 09:58 PM
anticrombie
You can read a 98's codes with a scanner, just not with the on/off trick.
Charlie
post #9 of 13 Old 07-15-2006, 12:51 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Extracting Fault Codes:
Turn the ignition switch ON, OFF, ON, OFF, ON and observe the CHECK ENGINE LIGHT. The CHECK ENGINE LIGHT should begin to flash a series of codes. The flashes will be separated by short and long pauses. The long pauses separate the "ones" and "tens" positions, and each code from the next. A code 55 will be displayed at the end of the test.
Here is another method that I found on the web
Extracting Fault Codes OBDII
Newer (OBDII) models - Put the key into the ignition, push down the odometer reset button, then turn the key to RUN with your finger on the button - and then release the button. The odometer will go through 1111111 through 999999, and then display the car's serial number. It will then show the error codes (it might show them starting with P). If this method does not work, try the OBDI method.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #10 of 13 Old 01-11-2011, 07:23 PM
webibeay
2004 KJ Liberty
Hey Folks -
I need a hand BAD! - I fried my transmission in my '98GK the day before Christmas. I had it rebuilt and all the sensors etc... replaced.
I got the truck back last night and it runs great, but my check engine light came on this eve... and I'm trying to figure out if it's something to-do with the tranny or did something else let go.
I did the key thing... and the lights flash once... pause, and then flash twice. What the hell does that mean????
UGH!
Bill
Bill/Bristol, RI
2004 Jeep Liberty/KJ
2012 Ford Fusion Sport
webibeay is offline
post #11 of 13 Old 01-11-2011, 07:33 PM
ZJ_This
Just take it to autozone and ask them to run the code, the on off thing doesn't work on 98's.
2011 Grand Cherokee Overland: All stock for now...
ZJ_This is offline
post #12 of 13 Old 01-11-2011, 07:41 PM
webibeay
2004 KJ Liberty
Really? I did the key thing... counted the blinks and checked against the website below.... is this not accurate?
http://www.allpar.com/fix/80s-codes.html
Bill/Bristol, RI
webibeay is offline
post #13 of 13 Old 01-11-2011, 08:04 PM
FPKites
ZJjazzyJim
FPKites's Avatar
This has been discussed before. Most 98 model year ZJs cannot use the key trick. Your local chain auto parts store should be able to pull the codes for free.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
97 ZJ check engine light...on, got codes but need help! jamoka3 ZJ Grand Cherokee Forum 5 06-20-2009 07:47 PM
Strange Check Engine light codes? klockdoc ZJ Grand Cherokee Forum 7 02-18-2009 07:25 AM
Check Engine Light with no codes? swataz ZJ Grand Cherokee Forum 2 09-22-2008 11:14 AM
Check Engine Light Codes -Joe- ZJ Grand Cherokee Forum 0 07-02-2008 02:02 AM
How to pull codes? Check engine light came on. TJs06TJ ZJ Grand Cherokee Forum 4 09-23-2007 05:16 PM
