Check Engine light with mind of its own - JeepForum.com
post #1 of 6 Old 06-21-2009, 08:18 PM Thread Starter
JkTheItalianoWJ
My check engine light keeps coming on and going off by itself from just driving from point a to point b. I dont understand why, it drives completely fine, theres no bad fuses or anything. Any Suggestions???
JkTheItalianoWJ is offline
post #2 of 6 Old 06-21-2009, 08:21 PM
Greeeeenberg
Do you shut it off right away when the light comes on? In order to get the code to stick you gotta drive or run it for a few minutes after it comes on
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #3 of 6 Old 06-26-2009, 07:14 PM Thread Starter
JkTheItalianoWJ
yeah i drive it the 2 times i went to a place to get it read with my stupid luck we came out with the code reader and it just went off
post #4 of 6 Old 06-26-2009, 07:15 PM
the88thpianoman
2003 WJ
Next time it turns out, pull over, turn off Jeep. Use key trick (on, off, on, off, on) and the odometer will display the code.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 6 Old 06-26-2009, 07:17 PM Thread Starter
JkTheItalianoWJ
alright man thanks i really appreciate it
post #6 of 6 Old 08-16-2009, 02:43 PM Thread Starter
JkTheItalianoWJ
hey come to find out it was my camshaft positioning sensor, everything is fine thanks guys for your suggestions
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
Power Washed Engine - Check Engine Light on Now Davis87YJ ZJ Grand Cherokee Forum 31 08-11-2008 08:17 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 01:49 PM
