Check Engine Light - JeepForum.com
post #1 of 2 Old 09-13-2003, 10:33 AM Thread Starter
Fisher
Check Engine Light
Hey Guys,
I saw a same kind of problem a while back. Somebody replied with a way to find out what the light is on for....a series of turning the ignition on and off....Does anyone know how to figure this out? Fisher
Fisher is offline
post #2 of 2 Old 09-15-2003, 10:43 AM
automan25
Start with key in ignition, all doors closed, and all power accessories turned off. Turn key to "On" (not "Start") position; this should be two clicks forward. Then turn key to "Off". Repeat one more time. Finally turn key back to "On" and leave it there. Wait about 20 seconds. The "Check Engine" light will begin to flash the code sequence. The sequence will begin and end with a 5. For example if you have codes 42 and 36 stored in the computer, then the sequence would look like this:
5, long pause, 4, short pause, 2, long pause, 3 short pause, 6, long pause, 5
Write down the codes and cross reference then with the ones listed in the Chilton manual, or the factory service manual.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 10:31 PM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 09:04 PM
Power Washed Engine - Check Engine Light on Now Davis87YJ ZJ Grand Cherokee Forum 31 08-11-2008 09:17 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 08:28 AM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 02:49 PM
