Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine - JeepForum.com
post #1 of 8 Old 02-03-2010, 12:54 PM Thread Starter
Keith1975
Hello, the check engine light is on in my mom's 1995 jeep grand cherokee limited 4x4 with the 4.0 six cylinder engine and I was able to pull the codes by turning the ignition key to On, Off On, Off and then back to On and the following codes came up: 12, 41 and 55.
What do those codes mean? I tried checking the link under frequently asked questions about the trouble codes but the link doesn't work. She just had the oil change done on it yesterday at Lube Stop in Barberton, OH and the check engine light came on after she had the oil changed and was on her way home.
Keith1975 is offline
post #2 of 8 Old 02-03-2010, 01:37 PM
JesseOR
12-battery input to PCM disconnected in last 50 start cycles.
41-an open or shorted condition in generator field control circuit(alternator I think)
55-test complete
Go get alternator tested. Was the gauge different than normal?
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #3 of 8 Old 02-03-2010, 02:44 PM Thread Starter
Keith1975
55-test complete
Thank you very much for the information What gauge were you refering to? She said it seemed like it was running fine after the oil change but the check engine light came on so yea I'll have the alternator tested and see what is up.
post #4 of 8 Old 02-03-2010, 04:30 PM
JesseOR
The battery/charge gauge. But many people just over look it so she probably didn't notice anything.
-Jesse-
GO DUCKS!
JesseOR is offline
post #5 of 8 Old 09-11-2010, 10:54 AM
MustangJAB02
55-test complete
How do you read the codes? this is my blinking pattern: l ll lllll l lllll lllll
is it grouped into pairs? 12, 51, 55? is that right?
If that is right then here is a list of the codes for everyone else so they can diagnose themselves.
http://www.nagca.com/grandtech/troubleshootcodes.htm
1995 Jeep Grand Cherokee Laredo
4.0L 201k+ miles (no rebuild yet)
Everything original except the normal replacing of mufflers, tires, spark plugs, but all done with stock replacement.
MustangJAB02 is offline
post #6 of 8 Old 09-11-2010, 11:18 AM Thread Starter
Keith1975
Hello all and thanks for all the replies but my mom traded the 95 grand cherokee in and got an 07 Jeep Commander 4x4 :-)
post #7 of 8 Old 09-11-2010, 06:19 PM
JesseOR
Troubleshoot Codes
yes, that is correct. that is the link i have always used as well, but it is also available in any service manual
-Jesse-
GO DUCKS!
JesseOR is offline
post #8 of 8 Old 11-04-2014, 09:31 PM
95gcawd
I just checked mine and got III III II IIIII IIIII
What does the II stand for?
95gcawd is offline
96 Jeep Grand Cherokee Check Engine Light djdoug99 ZJ Grand Cherokee Forum 21 03-26-2015 12:02 PM
2000 grand Cherokee I6 check Engine light spawnofsatan ZJ Grand Cherokee Forum 13 10-08-2008 03:19 PM
Check Engine Light 07 Grand Cherokee Selby WK Grand Cherokee & XK Commander Forum 3 04-22-2008 09:12 AM
early 95 grand cherokee check engine light CJ7Rubicon ZJ Grand Cherokee Forum 13 03-15-2007 01:51 PM
2002 Jeep Grand Cherokee Laredo 4x4 Check Engine Light Jeep2002 ZJ Grand Cherokee Forum 3 09-20-2005 10:44 AM
