Check engine Evap code - Page 2 - JeepForum.com
post #16 of 29 Old 02-08-2016, 10:13 PM Thread Starter
Football47
Okay, thanks for the advice, I'll look at those connections as well soon. So when I have this all fixed up, when will my jeep know it's fixed and turn the check engine light off?
Can't beat a Jeep
Football47 is offline
post #17 of 29 Old 02-09-2016, 02:25 AM
Uniblurb
Uniblurb's Avatar
Disconnect the negative terminal on the battery which should remove the fault codes and reset the PCM. That code shouldn't reappear if your evap system is working correctly and maybe even your tape job is a temp fix.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #18 of 29 Old 02-09-2016, 02:12 PM Thread Starter
Football47
I know of this method but I was wondering if it would do it on its own. Not with my help.
Can't beat a Jeep
post #19 of 29 Old 02-09-2016, 07:19 PM
ZeeJay1997
it will eventually turn the CEL off. Not sure but I think it's 3 full warm-up / cool-down cycles.
ZeeJay1997 is offline
post #20 of 29 Old 02-11-2016, 08:23 PM Thread Starter
Football47
It was the piece I fixed, code is gone and thanks for the help!
Can't beat a Jeep
post #21 of 29 Old 10-09-2016, 11:07 AM Thread Starter
Football47
Originally Posted by kg6mov
Yeah, only CA emissions jeeps have the LDP, so only CA emissions jeeps can pop the code. Fed emissions doesn't monitor the evap system at all, you could rip it out and the computer would be none the wiser.
so I could actually just disconnect the purge solenoid, ldp, and that's all I'd have to do and no codes?
Can't beat a Jeep
post #22 of 29 Old 10-09-2016, 08:04 PM
kg6mov
Hears the voices
kg6mov's Avatar
No, if you an LDP then it would throw a code.
If you are a federal emissions and don't have an LDP then you could remove it assuming it's a trailer queen that doesn't get driven on public roads.
kg6mov is offline
post #23 of 29 Old 10-10-2016, 08:01 PM Thread Starter
Football47
No, if you an LDP then it would throw a code. If you are a federal emissions and don't have an LDP then you could remove it assuming it's a trailer queen that doesn't get driven on public roads.
Yeah well that doesn't help because it's a daily driver...
Can't beat a Jeep
post #24 of 29 Old 10-11-2016, 07:56 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I was surprised by that particular hose on the carbon cannister on mine. Looks like mopar used regular vacuum hose instead of fuel resistant hose. Reason? The nipple on the cannister is a good bit larger than the actual size of the line. They needed something soft to be able to stretch it over the cannister nipple. Fuel line is a good bit stiffer. Guess they didn't want to spend the dough on another custom hose.
I found a little vacuum adapter in the help section at Advance where I could couple the larger nipple to fuel hose then to the smaller line.
Originally Posted by HighLonesome
coralman is offline
post #25 of 29 Old 10-16-2016, 10:37 AM Thread Starter
Football47
So, I have still not figured out the problem. When I reset the check engine, it doesn't come on for a few days. It's not the purge solenoid, and I don't see any leaks in the lines. I didn't see any charcoal dust in the old purge solenoid.my locking gas cap is three years old, it couldn't possibly be that? I've inspected it and it seems to be OK.
Can't beat a Jeep
post #26 of 29 Old 10-17-2016, 11:52 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
Do a smoke test (aka cigar test). That's the only way you'll be able to visually see where the leak is at. The gas cap is often the problem. You might as well throw 10 bucks at a new cap to see if it fixes it first.
That's exactly right, more specifically 3 open/close loop cycles.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, Jones Exhaust A3518M-5
rep-tile is offline
post #27 of 29 Old 10-19-2016, 09:27 AM Thread Starter
Football47
In the past I've had the check engine light come on before when I got low on gas then turn off a couple days or even the next day. I'm guessing it turned on because of vapor pressure build up in the evap lines and tank and there was probably a small leak....
Can't beat a Jeep
post #28 of 29 Old 01-10-2017, 04:57 PM Thread Starter
Football47
Well I had the light off for awhile until it got warm out, then it came back on. Where on the rubber lines should I specifically look for a cut in the hose? And I'm so sure that it's not the gas cap but is there anyway to make sure I have tight seal besides buying another new one? It seems fine until the warmth builds pressure in the system...
Can't beat a Jeep
post #29 of 29 Old 01-17-2017, 11:59 AM Thread Starter
Football47
There has to be a problem in the gas tank or gas tank neck. I only have check engine problems in the summer when the gas vapors expand. There isn't enough room in the evap lines to have the vapors be a problem.
Can't beat a Jeep
