Check engine codes - JeepForum.com
post #1 of 3 Old 06-15-2003, 04:02 PM Thread Starter
Tyler_Basham
Check engine codes
What do codes 12 and code 55 mean. i did the on/off/on/off/on and wroted down the numbers. If you know please post or email me.
Tyler Basham
Tyler_Basham is offline
post #2 of 3 Old 06-15-2003, 09:07 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
12 = Problem with battery connection. Direct battery imput to PCM disconnected within the last 50 ignition key cycles.
55 = Completion of fault code display on CHECK ENGINE lamp. This is an End of message code.
Haynes for 95 and earlier models.
For 96 and later
12 Battery power to PCM was disconnected
there is no 55.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 3 Old 06-17-2003, 10:03 PM
sup2nrmkiii
sup2nrmkiii's Avatar
I get code 12 also, what's with that?
Where would I start looking to fix this prob?
sup2nrmkiii is offline
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
check engine codes...how to? ponytail77 ZJ Grand Cherokee Forum 3 01-31-2010 07:08 PM
Check Engine Light Codes -Joe- ZJ Grand Cherokee Forum 0 07-02-2008 02:02 AM
Check engine codes 21 and 52 lma1973 ZJ Grand Cherokee Forum 16 09-09-2007 06:18 PM
Check Engine Codes rossj711 ZJ Grand Cherokee Forum 4 01-07-2006 08:11 PM
