Check Engine Codes - JeepForum.com
post #1 of 5 Old 01-07-2006, 12:07 PM Thread Starter
rossj711
Check Engine Codes
I have these engine codes and I don't understand them.
They go 1 pause 2 pause 5 pause 1 pause 2 pause 1 pause 5 pause 5
I understand 12. Battery disconnect.
51?
21?
Am I correct on those?
rossj711 is offline
post #2 of 5 Old 01-07-2006, 12:31 PM
greasefingers
greasefingers's Avatar
1994 ZJ
you forgot 12. Which is no biggie, but it appears that you need a O2 sensor. The code 51 is related to 21.
Extracting Fault Codes:
Turn the ignition switch ON, OFF, ON, OFF, ON and observe the CHECK ENGINE LIGHT. The CHECK ENGINE LIGHT should begin to flash a series of codes. The flashes will be separated by short and long pauses. The long pauses separate the "ones" and "tens" positions, and each code from the next. A code 55 will be displayed at the end of the test.
Diagnostic Trouble Codes - 1995 Jeep
11 IGN reference signal.
12 Battery input to PCM disconnected during last 50 key starts.
13 Fault in the map sensor pneumatic circuit.
14 Fault in the map sensor electrical circuit.
15 Fault in the vehicle speed sensor circuit.
17 Engine running too cool.
21 Problem in the oxygen feedback circuit.
22 Fault in the coolant temperature sensor circuit.
23 Air temperature sensor.
24 Intake air temp. sensor voltage high.
25 Fault in the IAC motor drive circuit.
27 Fault in injector driver interface circuit.
33 Fault in air conditioning cutout relay circuit.
34 S/C solenoid circuits.
35 Fault in fan relay circuit.
41 Fault in the charging system or no field current.
42 Fault in the ASD relay driver circuit.
44 Battery Temp Voltage.
46 Battery voltage is too high.
47 Battery voltage is too low.
51 Lean condition is indicated.
52 Rich condition is indicated.
53 Internal problem in module.
54 No cam position signal.
55 Completion of fault code display.
62 Unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 5 Old 01-07-2006, 12:31 PM
signalmtnjeep
from http://jeephorizons.com/phpbb/viewtopic.php?t=2719
21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor
51 Oxygen sensor stuck at lean position (this may be tripped by a bad MAP sensor system causing a rich condition. If you get hot rough idle and stalling, especially on deceleration, accompanied by flooded engine and difficulty restarting, that can be a bad MAP sensor causing the O2 sensor to try to compensate. If you get poor cold driveability, stumbling and bucking, and acceptable warm driving with poor gas mileage (a drop of 10 mpg or more), that is usually the O2 sensor.
51 Internal logic module fault ('84 turbo only).
Tripp
97 chargold ZJ.....4" lift done correctly....SOLD!!!!!!!!!!!!!!
replaced by 91 toyota Straight Axle swapped. (selling)
2004 WJ Overland black 4.7 HO (parents)
Looking for an XJ now.
signalmtnjeep is offline
post #4 of 5 Old 01-07-2006, 05:45 PM Thread Starter
rossj711
Well. Here are more details for a possible diagnosis.
Before I got my edelborck performance headers and flowmaster exhaust, the check engine light would appear usually on the highway when approaching hills and so forth. Maybe the Jeep had difficulty figuring how much gas to send? That would probably indicate a bad O2 Sensor, correct?
After I got my performance exhaust/headers installed, the check engine light will appear no matter what within a few minutes of driving.
Also, I had cracked pcb valves on the tops of the engine gasket, I did some work to them and they appear fine. But this could also be an issue.
Let me know what you think.
rossj711 is offline
post #5 of 5 Old 01-07-2006, 09:11 PM
greasefingers
1994 ZJ
How is it driving? If itís smooth when cold but irregular once the thermostat opens, then it would support the oxygen sensor.
Cheers Steve
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 09:04 PM
check engine codes...how to? ponytail77 ZJ Grand Cherokee Forum 3 01-31-2010 08:08 PM
Check Engine Light Codes -Joe- ZJ Grand Cherokee Forum 0 07-02-2008 03:02 AM
Check engine codes 21 and 52 lma1973 ZJ Grand Cherokee Forum 16 09-09-2007 07:18 PM
Check engine codes Tyler_Basham ZJ Grand Cherokee Forum 2 06-17-2003 11:03 PM
