Check Engine Code po300 - JeepForum.com
post #1 of 5 Old 09-15-2013, 05:23 PM Thread Starter
JeepgrlFl
I keep getting a po300, 302, 303, 304, and 305 check engine light reading. I put in a fuel injector cleaner a month ago. I'm at a loss of what to do. My mechanic is no help and wants to charge me an arm and a leg to do bunch of things I didnt really understand. Any suggestions???
JeepgrlFl is offline
post #2 of 5 Old 09-15-2013, 05:33 PM
Oldfrog
2007 WK
Please complete your profile about your Jeep.
Which engine? What year model?...etc.
Ok...haha...I see you were doing that as I was typing.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 5 Old 09-15-2013, 05:38 PM
Oldfrog
2007 WK
Multiple misfires.
Symptoms?
Oldfrog is offline
post #4 of 5 Old 09-16-2013, 06:38 AM
newfieZJ
Typically , a tune up will cure this issue . Plugs , wires , cap and rotor .
Occasionally , a weak coil can do it . Bad grounds might make the coil signal weak also . Check and clean connections
Fuel pressure should be tested with a gauge , and can cause the issue if not right
Bad or poor signal from the crank position sensor (CPS)
Check wires around exhaust for any shorts
Lastly , valve springs . 97-98 apparently saw a batch of weak springs . Jeep has a TSB to address that problem which is nothing more than replacing the valve springs and cleaning the carbon that typically builds up from this problem out the combustion chambers causing the mis-fires .
Attempt a good misting with a water hose while the engine is running . See if it starts running rough . Good ignition systems can handle a little water with no effect .
Disconnect the battery , clear the codes . Give 30 mins disconnected to be certain it's cleared . As soon as the jeep tosses a check engine light , check the codes ASAP , report results here .
newfieZJ is offline
post #5 of 5 Old 09-16-2013, 07:30 AM
johns1mj
When you change your cap and rotor check the distributor shaft for movement. I have seen a couple of these "wobble" from the bushings going bad.
johns1mj is offline
check engine light
