Check engine code 13? - JeepForum.com
post #1 of 4 Old 07-09-2011, 04:21 PM Thread Starter
Grand93Cherokee
"Indicates a problem with the manifold absolute pressure sensor vacuum source"
Can someone translate this to something I can understand, and how to solve this problem?
Thanks!
2014 JK
3.5 Lift
Stock
Grand93Cherokee is offline
post #2 of 4 Old 07-10-2011, 07:55 AM Thread Starter
Grand93Cherokee
Bump! Need some help ASAP.
2014 JK
3.5 Lift
Stock
post #3 of 4 Old 07-10-2011, 08:13 AM
mudruna
1994 ZJ
not sure of the location but the MAP sensor is on the intake manifold, there should be a couple of wires coming out of it and apparently a vacuum line. check the connection and that the vacuum line doesn't have any leaks, or it could be bad sensor.
94 ZJ Limited- 7" IRO premium, 4.56 gears on Elockers and Chromo's, 35" claws on beadlocks, Kevin's sliders
mudruna is offline
post #4 of 4 Old 07-10-2011, 08:30 AM
ZombieJeep93
#13: Slow change in MAP from start to run. Basicly, the PCM didnt see a significant change in the sensor reading from when the truck was starting to when it was at idle. Its on the firewall just to the drivers side of engine, has a vacuum line and an electrical connector. Check vac line for blockage or being pinched or disconnected. Most likely is a failed sensor. If your able to, check for 5volts on pin 3 (violet with white stripe) and ground on pin 1.
93 Grand Wagoneer (de-wooded) 5.2 Mag, 2"BB, Magnaflo Cat, Gibson ex, K&N CAI, Mopar pcm, 32" BFG AT, Accel truck ignition
ZombieJeep93 is offline
