-   -   Check engine code 13? (http://www.jeepforum.com/forum/f13/check-engine-code-13-a-1237539/)
Grand93Cherokee 07-09-2011 04:21 PM
"Indicates a problem with the manifold absolute pressure sensor vacuum source"
Can someone translate this to something I can understand, and how to solve this problem?
Thanks!
Grand93Cherokee 07-10-2011 07:55 AM
Bump! Need some help ASAP.
mudruna 07-10-2011 08:13 AM
not sure of the location but the MAP sensor is on the intake manifold, there should be a couple of wires coming out of it and apparently a vacuum line. check the connection and that the vacuum line doesn't have any leaks, or it could be bad sensor.
ZombieJeep93 07-10-2011 08:30 AM
#13: Slow change in MAP from start to run. Basicly, the PCM didnt see a significant change in the sensor reading from when the truck was starting to when it was at idle. Its on the firewall just to the drivers side of engine, has a vacuum line and an electrical connector. Check vac line for blockage or being pinched or disconnected. Most likely is a failed sensor. If your able to, check for 5volts on pin 3 (violet with white stripe) and ground on pin 1.
The time now is 04:32 AM.
