-   -   Check Engine (http://www.jeepforum.com/forum/f13/check-engine-25825/)
bradmere 12-30-2002 01:56 AM
Check Engine
A little over a month ago when it was starting to get cold outside i started my 96 6 cylnder jeep grand cherokee laredo and it almost died out until i pressed the gas and it started fine. A day later the check engine light came on and i got on the expressway and my jeep started to shake reall bad, then it stop and the check engine light blinked on and on. Every since then the light has been on and off on different days. When i idle the car shakes a little and the muffler is sputtering the exhaust. The computer checks that I have had done have indicated a cylinder misfire, first it was one or two and i replaced the wires, now it is all 6, and i have checked the distrubitor cap and the wires. The firing order is supposed to start with the number under the cap and it doesnt and when i change it to it the jeep wont start. I am not an expert with that kinda of stuff. Can anyone tell me what i am doing wrong and if they have a clue on what it could be.
Brad
MJR 12-30-2002 03:13 PM
It's not uncommon to get a multiple misfire codes when you are running out of gas. The ZJ's did have a problem with fuel sending units going out.
The time now is 01:25 AM.
