cheapest way to lift my zj? - JeepForum.com
post #1 of 19 Old 11-22-2007, 03:19 PM Thread Starter
93laredo
i have a 93 laredo v8..what is the cheapest way to get a bigger lift so i can fit 33"s? any suggestions are helpful!
93laredo is offline
post #2 of 19 Old 11-22-2007, 03:24 PM
Katesdad
Katesdad's Avatar
A jack. 33s are a whole new ballgame. If you got around $1000 US you can do it. Without regearing its going to not be so great...which costs even more.
Katesdad is offline
post #3 of 19 Old 11-22-2007, 03:34 PM
MAUSS
True. If you need to go that big with the tires, you should spend the money and do it right, or don't do it at all.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #4 of 19 Old 11-22-2007, 03:37 PM
sandman
a 10" body lift
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 19 Old 11-22-2007, 06:32 PM
nashmd454
nashmd454's Avatar
Amen to that....but I would have left my answer at just that....a Jack....A big one.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #6 of 19 Old 11-22-2007, 06:45 PM
CLASH
CLASH's Avatar
forget running 33s on the cheap. now you can do a 2 inch spacer and run 31s. I'd say that would be your best bet
95 zj, 4.5", 32" bfg at, locked rear.
CLASH is offline
post #7 of 19 Old 11-22-2007, 06:47 PM
Reswob
Remove the front fenders and trim the **** outta the rear. Cheap and easy.
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #8 of 19 Old 11-22-2007, 07:07 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Running 33's cheaply? Start by trimming, and when you think you have trimmed enough, trim some more.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #9 of 19 Old 11-23-2007, 01:42 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
This may seem like too much but, read it. IT'll make things very clear. Probably some things you haven't thought of.
This is from Ron. He couldn't have stated it better.
I'm starting to notice a large influx of newbies inquiring about lifting their jeeps around five to six inches. I'm wondering why you all desire this lift height and what you plan on accomplishing by doing so (ie. what size tires you want to run, specs on your lift/drivetrain, type of wheeling you plan to do).
The reason I ask is because, in my opinion, a 5-6" lift on a grand with short arms and stock axles/driveshafts is a very poor setup. This can be done but, the cost goes up!
Do you want to lift your ZJ 5-6" to fit a specific tire size? Do you realize the consequences on the drivetrain as a result of running that tire size? I'm guessing that most people who want to lift their grands this much are planning on running 33-35" tires, and that lift height/tire size is a wonderful combination that will likely not require excessive fender/bumper trimming and/or rediculously extended bumpstops. HOWEVER... to SAFELY and RELIABLY wheel on 33-35" tires, the axles will need to be regeared (especially if you have a 4.0L w/ 3.55:1 gears), or better yet, completely replaced with stronger axles capable of handling the loads that these bigger tires impose upon them. I swapped out my stock axles because I kept breaking them every time I went wheeling with my 33" tires...and even when my rig wasn't being wheeled, I was going through hubs and balljoints like crazy. I have ~4500$ in axle parts from doing my axle swap, and it would've cost a lot more had I not done all the work myself and made every single little bracket from scratch.
Control arm angles are another thing to consider. Anything above about 4" of lift makes for noticeably steep control arm angles. These steep angles suck because they do not allow the suspension to work properly. As the control arm angles get steeper, their bushings start to become the absorbers of vertical movement of the axle, which is supposed to be absorbed/dampened by the shock absorbers. Also, everytime a bump in the road is hit, the front axle not only travels up as usual, but it's also now forced to travel forward following the arc of the control arms pivoting at the frame...the more severe the CA angles, the more forward movement the front axle is forced to make when a bump is hit. This is not really a factor for the rear axle, as it is forced backwards when it goes up...which is much easier for it to do as the vehicle is traveling forward. Taking note of this should make it easy to understand why steep CA angles result in poor ride quality.
Another thing to think about with a 5-6" lift is poor steering geometry. The inverted "Y" design of the stock ZJ steering works very well at stock ride height since the tie-rod and drag link are relatively close to parallel. As the vehicle is lifted, the tie-rod and drag link become more perpendicular. Due to the geometry of the inverted "Y" steering, the toe of the tires will change significantly when a bump is hit if the two links are not close to parallel. If you can't visualize why this happens, make a quick model of your stock steering with a couple pencils and notice how the ends of the links where the steering knuckles would be move together and apart as the "ride height" changes via the mock pitman arm. The rapidly changing toe angles of the front tires after hitting a bump is a primary source of the dreaded deathwobble.
Have you thought about driveshafts? Odds are good that with 5-6" of lift and stock axles, you will have a very difficult time adjusting the caster of the front axle correctly without introducing terrible vibrations from the front driveshaft. With a double-cardan style front driveshaft, the axle pinion should be pointed directly at the transfercase...if it is not, the driveshaft will likely vibrate like a *****...which will not only annoy the crap out of you, but it will also quickly wear out your driveshaft U-joints, pinion bearings, and transfercase output bearings (these vibrations may also result in female passengers reaching orgasm while riding in your jeep, but we all know the female orgasm is only an urban legend anyway). So since the front axle needs to be close to its stock orientation to maintain decent caster, the pinion will not be able to point at the t-case like it needs to.
The rear driveshaft is not as much of an issue as the front axle if adjustable lower rear control arms are used. Adjustable/longer control arms will allow you to rotate the rear axle back to a "level" (stock) position, and will result in proper d/s angles so that vibrations should be minimal.
There are several other things I could go into detail on, but they're not quite as significant as the issues stated above.
But basically what I'm trying to make a lot of you realize is something I've stated several times before: you can lift a grand to about 4" very easily, safely, and inexpensively...but lifting it the next couple inches is a huge step that opens a huge can of worms that will likely cost you a small fortune.
So if you are a newbie to wheeling grands and are curious about lifting it, I'd strongly recommend you keep it at 4" or less lift and 32" or smaller tires unless you are very dedicated to working on it and wish to spend obscene amounts of money on it to make it drive and wheel properly. Keep It Simple Stupid!
If ya'll don't understand some part of this or need further clarification on anything, or disagree with anything I've written, speak up and I'll gladly address your concerns.
If you do it on the cheap, it'll ride like junk.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #10 of 19 Old 11-23-2007, 01:52 PM
sandman
pssst.... i am running 6'' with 8 adjustable short arms and my ride is just fine. arent you doing the same texaszj? plus arent you running 35s on a super 35? my point is if done right you can fit big tires on short arms and fairly stock axles, but by no means is it considered cheap.
1993 Jeep ZJ. 4.0
sandman is offline
post #11 of 19 Old 11-23-2007, 01:55 PM
Yardman Harry
O
Yardman Harry's Avatar
Its too bad when the FAQs have to be reposted because of a user's negligence to understand how a forum works.
Do a F>R swap, you will probably be able to get away with most things stock, depending on the condition of your suspension. Then you could fit 32s in there with some trimming.
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #12 of 19 Old 11-23-2007, 01:58 PM
sandman
yea but i think that the faq section can be decieving. it pretty much says to run 33s you need a long arm kit and a stronger rear axel. the first time i read it i was pissed because i thoight i was going to need to spend thousands to achieve what i wanted when in reality there are other ways.
1993 Jeep ZJ. 4.0
sandman is offline
post #13 of 19 Old 11-23-2007, 02:20 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Wrong answer bubba - read again. You can squeeze 33s in there with 4.5" and adjustable arms (not longarms, but it would be smart). I've seen 4.5" on stock arms and 33s, and it wasn't pretty. That's the reason I'm on 32s. The Dana Turdy-Five can snap like a twig with 33+, but it can be done if you do it smart. Regear, and you'll have a chance at running 33-35s on a turd.
There's a reason we have so many items in the FAQ - people have tried it. Read up, and you'll learn a lot.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #14 of 19 Old 11-23-2007, 02:27 PM
sandman
yea ive read the whole faq section. i just think it can have a tendency to scare the noobs away. jerk! lol.. just kidding.
you do make a good point though it does say it can be done. but it makes it sound youre gonna break shafts everytime you go wheelin and and like 6in on SAs will ride like crap when my ride really isnt that bad. i am on 32s but when they wear out im going with 33s and some gears.
1993 Jeep ZJ. 4.0
sandman is offline
post #15 of 19 Old 11-23-2007, 03:54 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
Do a Spacer lift and then trim the heck out of the fenders. That will fit 33"s. Then regear unless you have a V8.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
Cheapest way to get a quality lift on my 5.9 59strt8 ZJ Grand Cherokee Forum 10 12-12-2009 11:58 AM
The cheapest 4.5 inch lift ZJForBreakfast ZJ Grand Cherokee Forum 13 02-10-2008 08:46 PM
cheapest lift possible pudgex3 ZJ Grand Cherokee Forum 4 01-23-2007 09:40 AM
Best/cheapest place to buy 4'' lift for ZJ? seyser ZJ Grand Cherokee Forum 4 06-28-2006 10:00 PM
What's the cheapest way to lift my ZJ 3"? Only In A Jeep ZJ Grand Cherokee Forum 2 07-16-2004 09:18 PM
