Cheapest OEM Mopar Crank Position Sensor... - JeepForum.com
post #1 of 17 Old 01-18-2013, 03:53 PM Thread Starter
JeepinJordan
Engine cutting off , dying and hard starts with a 11 CEL code confirm a bad CPS.
Where can I find the cheapest Mopar sensor that will fit my 1996 4.0 Automatic 2wd ZJ???
Thanks.
JeepinJordan is offline
post #2 of 17 Old 01-18-2013, 04:14 PM
bananaslug
mopar-wholesale.com
49.68 plus shipping
bananaslug is offline
post #3 of 17 Old 01-18-2013, 04:49 PM Thread Starter
JeepinJordan
Anyone know if its a 1 or 2 bolt also?
-Bone stock 1996 Jeep Grand Cherokee Laredo 4.0L
post #4 of 17 Old 01-18-2013, 04:59 PM
bananaslug
if you go to the website and put in all the vehicle info it gives you the right one. Ours will be a one-bolt.
post #5 of 17 Old 01-18-2013, 05:09 PM
Uniblurb
Uniblurb's Avatar
That is a good price Bananaslug since it's $59.99 + $9.99 shipping on Amazon. The Mopar CKP OE # is 56027280 for the 96 4.0. Best to remove the 1 bolt on the top left bell housing with a 11mm or 7/16" swivel socket (both fit) from underneath with a long extension. Then remove/install the CKP from the top. Make sure you unplug the battery first. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #6 of 17 Old 01-18-2013, 05:32 PM
KoreaZJ
1994 ZJ
Originally Posted by bananaslug View Post
mopar-wholesale.com
49.68 plus shipping
Have ordered lots of parts from here. Great prices, but shipping/handling is a little high when ordering only one small part. I usually order a few parts at once. Contact Bobby for info/quote.
sales @ mopar-wholesale . com
KoreaZJ is offline
post #7 of 17 Old 01-18-2013, 08:13 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
This place is in florida isn't it? Or there may be another place with the same name without the hyphen. I live in florida so to use them they would nail me on sales tax.
Originally Posted by HighLonesome
coralman is offline
post #8 of 17 Old 01-19-2013, 02:25 AM
KoreaZJ
1994 ZJ
Tampa, FL
KoreaZJ is offline
post #9 of 17 Old 01-20-2013, 10:36 AM Thread Starter
JeepinJordan
Originally Posted by KoreaZJ View Post
Tampa, FL
Thanks all, I will order tonight and expect to have this problem fixed this week since I also live in FL.
post #10 of 17 Old 01-20-2013, 12:25 PM
Uniblurb
Uniblurb's Avatar
Good time to clean the 3 engine grounds before installing your new CKP if you haven't already done so. There's 1 on the oil dip stick tube bracket and 2 on the coil bracket studs. One of these on the coil studs grounds the PCM which is turn grounds all the sensors. I learned the hard way and a rusted/corroded/oil-covered PCM ground took out my PCM along w/the CKP. Just thought I'd pass this along and good luck.
post #11 of 17 Old 01-22-2013, 11:32 AM Thread Starter
JeepinJordan
mopar-wholesale.com
49.68 plus shipping
Got it today! Fast shipping, inexpensive OEM parts and easy service on the site. Thanks,
I will update you guys if this fixes my problem.
post #12 of 17 Old 01-23-2013, 03:12 PM Thread Starter
JeepinJordan
Unfortunately... Did not solve my problem.
post #13 of 17 Old 01-23-2013, 04:21 PM
bananaslug
It would have gone out eventually anyways. Dont feel too bad, and keep the old one as a spare.
post #14 of 17 Old 01-23-2013, 04:32 PM
Trick440
1994 ZJ
Sucks it didn't fix it. I just went through this and spent about 4hrs with a manual and multimeter running tests. Found out it was the cps.
Still end up spending an extra $30 on a pick up coil I didn't need.
Trick440 is offline
post #15 of 17 Old 01-23-2013, 06:48 PM Thread Starter
JeepinJordan
Yes I am keeping it. Thanks.
cps
