Cheap ZJ mods thread. - Page 3 - JeepForum.com
 1Likes
post #31 of 138 Old 02-21-2012, 10:29 PM
pincheburro956
::::::: Mod Name: 5.2L Power steering bracket.
::::::: Why Worth It: factory ones are crap, stop belt whining and belt being spat out of "track".
::::::: Cost: 0-$10, if you have some of the materials.
::::::: Where to buy: spare steel, and autozone
::::::: Time required:<1hr.
::::::: Difficulty: 4, if you have a welder and a brain.
I made my own power steering bracket for my 5.2 since I had already broke 2 of the factory ones.
link here: http://www.jeepforum.com/forum/f13/j...acket-1312610/
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #32 of 138 Old 02-21-2012, 10:32 PM
JohnnyZJ
::::::: Mod Name: ujoint axleshafts
::::::: Why Worth It: ujoints are easier to fix on the trail, CVs generally suck
::::::: Cost: $25 at junkyard
::::::: Where to buy: junkyard
::::::: Time required: 1-2 hours
::::::: Difficulty: Moderate
good time to do new hubs as well.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #33 of 138 Old 02-21-2012, 10:34 PM
JohnnyZJ
::::::: Mod Name: swap CV drive shaft for ujoint driveshaft
::::::: Why Worth It: if you wheel you will break that CV shaft
::::::: Cost: not cheap. need a yoke from a D30 and a shaft that is long enough for your application. you should rebuild the DS too. probably 300$
::::::: Where to buy: jy
::::::: Time required: 3 hours
do your pinion seal at thes ame time
JohnnyZJ is offline
post #34 of 138 Old 04-15-2012, 09:18 AM
xbeakerx
bump, to get the thread moving again.
1998 ZJ Laredo(Gonzo) - Built Not Bought - 3.5" lift with IRO Long Arms, Cherry Bomb Exhaust, 31x10.50R15, CAI, Custom Front Recovery System & YJ Tube Bumper
1986 Toyota MR2 - Polyurethane Suspension Bushings,Suspension Techniques Lowering Springs,S/C Swap and more!
xbeakerx is offline
post #35 of 138 Old 07-19-2012, 05:49 AM
Scopez
1994 ZJ
Originally Posted by zander21510 View Post
::::::: Mod Name: Stock Airbox modification
::::::: Why Worth It: Elimination of hesitation, less restricted flow. Some claim more power.
::::::: Cost: Free
::::::: Where to buy: Nowhere
::::::: Time required: 15-20 minutes
::::::: Difficulty: Easy
::::::: DIY: Pull airbox and hose and grill snorkel thing. Remove white restrictor inside tube coming from airbox. OPTIONAL: If you don't go in sloshy mud, for less flow restriction remove grille snorkel thing, take out fiberglassy material in front of grille opening if blocking opening, and if desired dremmel out entire front of airbox.
::::::: Picture(s): will upload later
Looking to do this later on today just to see. Also, let's bring this thread back to life!
Scopez is offline
post #36 of 138 Old 07-19-2012, 08:58 PM
Dylan484
Nice
Dylan484 is offline
post #37 of 138 Old 10-20-2012, 01:14 AM
elkluvadore
::::::: Mod Name:More Power
::::::: Why Worth It:Running spotlights? Winch? Invertor? You'll want this.
::::::: Cost: $35
::::::: Where to buy: Craigslist
::::::: Difficulty: easy/moderate
With this mod you're going to upgrade your I6's 90 amp alternator to an 136 amp one. You're going to find this 136 amp alternator on many Dodge Durangos, and V8 Grand Cherokees (google for exact dates). These alternators will either drop straight in, or require you to switch out the back plate and plug on the new alternator, this requires 5 minutes work, and a bit of dremel work.
http://www.jeepforum.com/forum/f9/up...r-swap-918908/
elkluvadore is offline
post #38 of 138 Old 12-20-2012, 09:56 AM
Football47
::::::: Cost: Free
Pictures? and a bump
Football47 is offline
post #39 of 138 Old 12-20-2012, 10:04 AM
Football47
::::::: Mod Name: Rattle can rims
::::::: Why Worth It: Looks better than stock or solid color
::::::: Cost: $3 (1 can and tape)
::::::: Where to buy:Walmart
::::::: Time required: 30 minutes
::::::: Difficulty:1 out of 10
::::::: DIY: Tape on a design you like, than paint over it, simple!
::::::: Picture(s):
post #40 of 138 Old 12-20-2012, 10:08 AM
RagTagSoldier
::::::: Picture(s):
That looks badass lol
Sent from my iPhone using JeepForum and has probably been edited.
RagTagSoldier is offline
post #41 of 138 Old 12-20-2012, 10:43 AM
Football47
I AM THE MACGYVER OF ZJS! Where there is a will there is a way, like not wanting to spend money on ACTUAL rims lol
post #42 of 138 Old 12-20-2012, 11:09 AM
Football47
Zander, I've been trying to do the airbox mod but I just realized there is literally nothing of what you said in there.... guess the last person did it for me?
post #43 of 138 Old 12-20-2012, 11:38 AM
BoostinChick
Originally Posted by 98SilverBullet View Post
::::::: Mod Name: rear hatch lights
::::::: Why Worth It: rear lighting when needed
::::::: Cost: $10 so far, with new bulbs $30
::::::: Where to buy: junkyard off oldsmobile aurora
::::::: Time required: 1-2hrs
::::::: Difficulty:
::::::: DIY: out of 10, 3
::::::: Picture(s):
rear lights i sunk into my tailgate and they bolt on throught the factory plate holes
Originally Posted by Howieb92 View Post
^^^ what year would you guess?
More info, or link to write up PLEASE!
1998 Jeep Grand Cherokee 5.9L
BoostinChick is offline
post #44 of 138 Old 12-20-2012, 09:19 PM
jeepinbassist
The dash lights one would be even cheaper if you could just sharpie the lights...
jeepinbassist is offline
post #45 of 138 Old 12-21-2012, 01:20 AM
Football47
You can change out the dash lights for $12 and have an extra bulb left over for the shifter.... I did mine blue for the instruments and blue in the shifter. Led will cost a bit more, but it turned out good for me. Think I might do the rest blue!
jeep , mods , zj
cheap 4.0 mods? redneckwithajeep ZJ Grand Cherokee Forum 13 05-09-2014 01:40 PM
A few new cheap mods.. TheDude584 WK Grand Cherokee & XK Commander Forum 16 09-16-2009 08:46 PM
Cheap Mods? illz302 WK Grand Cherokee & XK Commander Forum 7 03-03-2009 03:44 PM
Zj Zj Zj Cheap Diy Mods Wj Wj Wj 97zjjeeper ZJ Grand Cherokee Forum 3 06-18-2007 01:41 PM
Cheap Mods staticjeep ZJ Grand Cherokee Forum 30 02-18-2006 11:39 AM
