Cheap ZJ mods thread. - Page 2 - JeepForum.com
 1Likes
post #16 of 138 Old 10-26-2011, 11:07 PM
98SilverBullet
1994 ZJ
::::::: Mod Name: rear hatch lights
::::::: Why Worth It: rear lighting when needed
::::::: Cost: $10 so far, with new bulbs $30
::::::: Where to buy: junkyard off oldsmobile aurora
::::::: Time required: 1-2hrs
::::::: Difficulty:
::::::: DIY: out of 10, 3
::::::: Picture(s):
rear lights i sunk into my tailgate and they bolt on throught the factory plate holes
94 zl 5.2, np242, d30, trussed, ujoint shafts, all 1\4" wall dom steering, 8.8 trac-loc, disk, custom front/rear bumpers, custom paint, k&n cai, tb spacer, gibson sidepipes. etc etc..
98SilverBullet is offline
post #17 of 138 Old 10-27-2011, 06:30 AM
Howieb92
^^^ what year would you guess?
Howieb92 is offline
post #18 of 138 Old 10-27-2011, 09:02 AM
Jon20683
::::::: Difficulty:
::::::: Picture(s):
That looks intresting and cool! More pics on that possiblewrite up?
Sent from my Ally using JeepForum because im useless
"20 year old Mass Guy"
96 ZJ Limited 5.2 Black/Gold
with some goodies
WTB=looking to by a zj I6 trans cooler-
TheSpeedFreaks.net
Jon20683 is offline
post #19 of 138 Old 10-27-2011, 09:17 AM
zander21510
oh i have quite a few...once i get to a computer off my cell ill write down a few
zander21510 is offline
post #20 of 138 Old 10-27-2011, 09:21 AM
somebody5788
1994 ZJ
I will be doing that rear light thing at some point for the trails, I didn't like the ones on the roof but those look somewhat factory and should be just as effective.
Plasti Dip the front grill is a really nice and cheap mod. I haven't done mine yet so I wont post the stuff yet, but I painted it in grill paint but it sorta peeled the chrome off when I taped the grill of to trim it so I have to do it again but I will be doing Plasti Dip this time.
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #21 of 138 Old 10-27-2011, 02:29 PM
zander21510
::::::: Mod Name: Bosch 703 injector swap for 4.0 or 5.2
::::::: Why Worth It: Better fuel spray pattern (4 holes vs 1 hole) resulting in smoother idle and faster start. Some claim better fuel economy.
::::::: Cost: Depends, cheapest to find JY injectors
::::::: Where to buy: JY or online (Bosch P/N 0280155703
::::::: Time required: Less than 15 minutes for a beginner
::::::: Difficulty: Easy
::::::: DIY: Dozens of threads, good writeup by melk, couldn't find it but in the mega injector thread he has good pics (here).
::::::: Picture(s):
post #22 of 138 Old 10-27-2011, 02:37 PM
zander21510
::::::: Mod Name: Stock Airbox modification
::::::: Why Worth It: Elimination of hesitation, less restricted flow. Some claim more power.
::::::: Cost: Free
::::::: Where to buy: Nowhere
::::::: Time required: 15-20 minutes
::::::: DIY: Pull airbox and hose and grill snorkel thing. Remove white restrictor inside tube coming from airbox. OPTIONAL: If you don't go in sloshy mud, for less flow restriction remove grille snorkel thing, take out fiberglassy material in front of grille opening if blocking opening, and if desired dremmel out entire front of airbox.
::::::: Picture(s): will upload later
post #23 of 138 Old 10-27-2011, 02:42 PM
zander21510
::::::: Mod Name: Paint Laredo cladding
::::::: Why Worth It: Update faded gray cladding
::::::: Cost: $20-25 worth of paint and sandpaper
::::::: Where to buy: Home Depot/Lowes/Walmart
::::::: Time required: 1 day, plus 2 days to dry
::::::: Difficulty: Moderate
::::::: DIY: My Writeup
::::::: Picture(s): In writeup, please be sure to read warnings because amount of masking shown in pictures WILL NOT SUFFICE TO PROTECT BODY PAINT.
post #24 of 138 Old 10-27-2011, 02:49 PM
zander21510
::::::: Mod Name: Cheap aftermarket Fog Lights
::::::: Why Worth It: Way cheaper/looks nicer than finding switches/OEM fogs/wiring.
::::::: Cost: $20-30 at Walmart depending on style desired
::::::: Where to buy: Walmart
::::::: Time required: 30mins-1hr
::::::: DIY: Requires a little creativity when it comes to mounting. I mounted rectangle fogs in my bumper cover grille thing, farther in than 96-98 stock fog location. Looks very nice. Wiring explained in manual, comes with toggle switch, most wires should reach. I assume for 96-98 without stock fogs you could mount the same lights where the vent things are for non OEM foglight models. Power wire can go to fuse box, must be at least 20A fuse (check box or manual for fog light power rating. Fog lights will have their own fuse, so make sure to use a fuse in fuse box at a higher amperage rating)
::::::: Picture(s): Will upload later
post #25 of 138 Old 10-27-2011, 03:03 PM
zander21510
::::::: Mod Name: PA system and/or CB radio
::::::: Why Worth It: Its fun! Plus highway cop/traffic warnings.
::::::: Cost: $25 Midland CB radio plus $50 Wilson Little Wii antenna, plus $20 PA speaker at least 50W
::::::: Where to buy: Amazon, some radio shacks
::::::: Time required: 1-2 hours
::::::: DIY: Not many places to mount a PA speaker, I found the best spot is inside the front bumper cover on the left side. You can screw it in from the bottom, screws will show but you can paint over them and they aren't that noticable. Wire can come up to behind the headlight and run along the edge of the hood to the cabin through the door. For the CB there are dozens of threads on mounting locations, even one to integrate it where the ashtray is. You can definitely find cheaper antennas, but the Little Wii is the best magnetic kind that doesn't require calibration. You get the best signal by mounting it near the rear center of the vehicle. Cable can be threaded over the doors behind the rain seal all the way to the front. For power, instead of taking power wire all the way to the battery you can just use an aux fuse (cigarette lighter fuse works well) and thread the little wire in there. Just be sure to ground it properly somewhere metal.
post #26 of 138 Old 02-21-2012, 10:04 PM
big_rudy101
"Jeep is America's only real sports car" - Enzo Ferarri
big_rudy101 is offline
post #27 of 138 Old 02-21-2012, 10:13 PM
JohnnyZJ
::::::: Mod Name: transmission fluid change
::::::: Why Worth It: so your tranny lasts long enough that you don't post up here asking for cheap solutions to your blown tranny
::::::: Cost: $40
::::::: Where to buy: if it has the word 'auto' in it, you can probably get a filter kit and fluid
::::::: Difficulty: apparently difficult otherwise people would do it more often.
buddah426 likes this.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #28 of 138 Old 02-21-2012, 10:14 PM
JohnnyZJ
::::::: Mod Name: diff fluid change
::::::: Why Worth It: after mud bogging and filling your diffs with chocolate milk, it'll save your diffs, and more useless posts on here
::::::: Cost: $25 for both diffs fluid and silicone to reseal
::::::: Where to buy: anywhere with 'auto' in the title
JohnnyZJ is offline
post #29 of 138 Old 02-21-2012, 10:17 PM
JohnnyZJ
::::::: Mod Name: tune up
::::::: Why Worth It: ur jeeps 13 - 18 years old. it needs it.
::::::: Cost: $cap, rotor, plugs, wires, oil change, injector flush, radiator flush, air filter, fuel filter.... start with that... price...... ummmm
::::::: Where to buy: any place with the word 'auto' in the title
::::::: Time required: 3-4 hours
JohnnyZJ is offline
post #30 of 138 Old 02-21-2012, 10:20 PM
JohnnyZJ
now; actual mod?
::::::: Mod Name: 231 or 242 swap
::::::: Why Worth It: ummmmm ya. 249s suck
::::::: Cost: $150 - 300$ for good used transfer case, 20$ new fluid
::::::: Where to buy: wrecker, ebay, craigslist etc
::::::: Time required:5 hours
::::::: Difficulty: might as well pay a shop to do it difficult
this is an easy swap if you hve half a brain and time/garage.............. time/garage is key. if you have a daily driver it makes it easier if you've not done it. i did mine in 2 hours. pull old np 249. rip case apart. take input out. rip 231 apart. put input from 249 in. reinstall transfer case. then do 2wd burnout
JohnnyZJ is offline
jeep , mods , zj
cheap 4.0 mods? redneckwithajeep ZJ Grand Cherokee Forum 13 05-09-2014 01:40 PM
A few new cheap mods.. TheDude584 WK Grand Cherokee & XK Commander Forum 16 09-16-2009 08:46 PM
Cheap Mods? illz302 WK Grand Cherokee & XK Commander Forum 7 03-03-2009 03:44 PM
Zj Zj Zj Cheap Diy Mods Wj Wj Wj 97zjjeeper ZJ Grand Cherokee Forum 3 06-18-2007 01:41 PM
Cheap Mods staticjeep ZJ Grand Cherokee Forum 30 02-18-2006 11:39 AM
