#1 | |
Cheap part not so cheap
I need help finding a part on my window regulator. The lower cable guide busted the other day. All I can find are replacements for the whole regulator, but all I need is the lower cable guide. So far price go from 300 bucks at the dealership to about 50 bucks on ebay. Does anybody know how to find the part # for this tiny little plastic peice that I need. or are there any suggestions on maybe fabbing one. any help is apreciated. oh ya it's on a 02 Grand cherokee limited front passanger side. thank you
#2 |
I had the same problem a while ago. I knew I would have to pull the door panel off to try and replace that lower cable guide. I figured I would just buy the part on ebay and replace the whole thing. It was worth it. Easy install. It doesn't roll up as fast as the other stock ones that came with the Jeep but all I care about is that it works. I had no luck trying to find the cable guide but then again I didn't look that hard cause I was set on just replacing the whole thing.
#3 |
Wondering if you could post a link to a pic of this guide. Also check GC partout sections on the various boards.
#4 |
I don't have a pic. It is that little half wheel on the lower part of the window regulator. the tab that connects it to the metal track snapped.
#5 |
Ken '01 WJ Laredo - 4.7L, QD, UC, GY Wrangler SA 245/65/17 tires, MX6 shocks, Stillen rotors (F/R) and MM pads, Addco F/R Sway Bars
#6 |
http://pocketlogger.com/instructions/jpw_install/Jeepwindowfix005.jpg no but close see the little half wheel on the bottom of the track where the lower cable is routed up into the channel that's the peice i'm looking for .
#7 |
None of the parts on the regulator are seviceable. You have to buy a whole new regulator. It's retarted, but tha's jeep for ya. If you can get a mopar one on ebay for about 80-100 that's a pretty good deal. The dorman aftermarkets work good too. I've replaced 3 of the 4 on my 2003.
#8 |
Ya I just went ahead and bought a new unit of ebay. oh well . thanks for the help guys.
#9 | ||
2004 4.0 Selec-Trac BB->Black Diamonds->General Grabbers Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
