Cheap but quality shocks? - Page 3 - JeepForum.com
post #31 of 60 Old 11-11-2011, 10:29 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Don't forget some take like 10 lbs of pressure to compress. So he could have got like a 40 lb lift lmao
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #32 of 60 Old 11-14-2011, 01:33 PM
iflypa28
Originally Posted by RedneckZJ View Post
lemme guess the rear stops bouncing about a mile down the road?
Originally Posted by badbird17x View Post
No because you hit another bump in that mile
thats true too...mine does that too...i figured they were defective
I just solved this problem on my ZJ!!! Maybe this isn't your problem but I have a suspicion it is. When I put my rough country shocks on I installed them upside down. They will go either way in the rear and nothing really tells you how they should go. Mine went from bouncing for a mile like yours to being nice and stiff after I swapped them around, it made a HUGE difference. Another important thing to know, and you may already, is that the steel sleeve that came with the shocks needs to be inserted in the bottom bushing for proper fitment of the bolt. This will also help reduce play in the shock. Im interested to see if this is your problem, if so I might do a write up on it. Just for clarification the correct way seems to be with the dust boot/skinny end up.
iflypa28 is offline
post #33 of 60 Old 11-14-2011, 06:28 PM
WhiteOut
WhiteOut's Avatar
Gas shocks can be mounted either way, body up or down changes the unsprung weight.
No need for a write up on a simple shock install.
WhiteOut is offline
post #34 of 60 Old 11-14-2011, 06:55 PM
iflypa28
Not sure exactly what unsprung weight means, I am curious if you want to explain. My shocks are actually hydro not sure what effect that has but it was a day and night difference when a switched them. At highway speeds it was almost dangerous when you hit a bump. I bet others have the same problem.
iflypa28 is offline
post #35 of 60 Old 11-14-2011, 07:25 PM
Foundrydude
Originally Posted by iflypa28 View Post
Not sure exactly what unsprung weight means, I am curious if you want to explain. .
Unsprung weight is weight that moves up and down with the axle.
Sprung weight is everything supported by the springs.
Rule of thumb.....When talking shock and springs, every unsprung pound added has the same effect as adding ten sprung pounds.
Example, a dana 60 frontend is AWESOME but will make your truck ride like azz cause it weighs 350 lbs and it takes the spring/shock rate of a 1 ton pickup to control that amount of mass.
So really a shock should be mounted so the rod end is toward the axle, because the shock body weighs more. This reduces the unsprung weight of the axle.
To the original question...I've had really good luck with KYB shocks on a street vehicle. Excellent dollar to quality ratio. However, I would not choose them if the vehicle was blasting thru mud holes or jumping railroad tracks at 50mph.
good luck!
Foundrydude is offline
post #36 of 60 Old 11-14-2011, 07:46 PM
iflypa28
Thanks for explaining that! I should have figured that out. I wonder why it was such a drastic improvement for me with the shock body down.
iflypa28 is offline
post #37 of 60 Old 11-14-2011, 07:47 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Could be valveing
post #38 of 60 Old 11-14-2011, 07:55 PM
iflypa28
Could be valveing
That's the only thing I can figure, the valving must be different for fluid moving one way as opposed to the other. How are yours mounted, I thought I saw somewhere that you have the bouncing problem too right?
iflypa28 is offline
post #39 of 60 Old 11-14-2011, 08:05 PM
badbird17x
badbird17x's Avatar
1994 ZJ
I'll look tomorrow
post #40 of 60 Old 11-14-2011, 08:38 PM
RedneckZJ
mine are mounted with the shock body up
'96 ZJ Orvis 5.2L (Mossy Oak Edit.)- UC+2" BB, Thrush Turbo, 2 12s, Lots Of Stickers
You drive a tj, we drive a zj. We have more power while you get more shower. We get the v8 while you get there too late. You have 2 doors well, we have 2 more. Ours costs a grand while yours has a price we cant stand.
RedneckZJ is offline
post #41 of 60 Old 11-14-2011, 08:50 PM
iflypa28
If you switch them I'm convinced it will fix it. Let me know if you do it, I'm curious.
iflypa28 is offline
post #42 of 60 Old 11-14-2011, 09:06 PM
RedneckZJ
im gonna try it this weekend im hoping itll fix it
post #43 of 60 Old 11-14-2011, 11:18 PM
TJdualsport
unless it says you can mount upside down dont do it. most twin tube shocks can not be run upside down.
my dual sport build http://www.jeepforum.com/forum/f22/project-bumptastic-947070/
TJdualsport is offline
post #44 of 60 Old 11-15-2011, 07:32 AM
iflypa28
That's the point, we think (or at least I think), they are upside down and that's causing the problem.
iflypa28 is offline
post #45 of 60 Old 11-15-2011, 07:42 AM
Foundrydude
If your shock has a metal sleeve to cover the rod that also controls orientation due to water drainage issues. Most sleeved shocks mount the shock body to the axle.
shock absorber
Looking for some good, cheap shocks.... VinceAustria ZJ Grand Cherokee Forum 2 11-09-2008 09:05 AM
Good Quality Shocks? raider650 ZJ Grand Cherokee Forum 15 09-27-2008 12:25 AM
Rocky Road BB Kit w/ Shocks...Quality? schmoo742 ZJ Grand Cherokee Forum 4 06-30-2008 11:34 AM
Cheap superlift ebay shocks gunthagunth ZJ Grand Cherokee Forum 0 05-31-2006 01:51 PM
bilstien shocks, cheap Kess ZJ Grand Cherokee Forum 0 03-03-2002 08:11 PM
