chasing down a steering issue - JeepForum.com
post #1 of 16 Old 12-02-2011, 06:13 AM Thread Starter
schapkern
Hey guys!
1997 ZJ Grand Cherokee Orvis
5.8l v8
177K+ miles
I've got an odd steering issue i've been trying to chase down. No wobble to speak of, but its just not right.
The steering is tight, no more than about 1" of OD wheel play but, to travel straight down the road the steering wheel has to be turned 1/8 to 1/4 to the left.
I had the allignment checked at the tire shop, they said it was good.
Tires are all inflated to 35.5psi cold.
adjusted the steering gearbox
Replaced the right upper and lower ball joints
both right and left hubs have about 2k miles
all the bushings in the front and rear have been replaced and have about 2K miles on them.
all brake components are new, replaced when I did the hubs and bushings
both the axle shafts have been replaced also done with bushings hubs and breaks
the tie rod ends look ok, they dont wiggle and i regreased them.
and new shocks
but still have this oddness in the steering.
Any Ideas? I was thinking of replacing everything from the pitman arm out to the tires. Pitman arm, drag link, inner and outer TRE, everything.
Thats expensive but if thats the way to go that's what I'll do
schapkern is offline
post #2 of 16 Old 12-02-2011, 06:20 AM
totalalign12
Originally Posted by schapkern
Hey guys!
5.8l v8
177K+ miles
and new shocks
Is it pulling one way or the other? Or is the steering wheel just crooked.
totalalign12 is offline
post #3 of 16 Old 12-02-2011, 06:22 AM
KoreaZJ
1994 ZJ
"1/8 to 1/4 to the left."
Inches? Or turns?
If it's not pulling to the side and the wheel is just off-center... adjust the drag link to center the wheel.
KoreaZJ is offline
post #4 of 16 Old 12-02-2011, 06:44 AM Thread Starter
schapkern
It wants to wander a bit to the right even if the wheel us turned an eighth to a quarter of a turn to the left
post #5 of 16 Old 12-02-2011, 06:47 AM Thread Starter
schapkern
Inches? Or turns?
you do this by turning the adjustment sleeve correct? is there a special tool for this?
post #6 of 16 Old 12-02-2011, 07:07 AM
KJK
It sounds like you need a second opinion on the alignment job.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #7 of 16 Old 12-02-2011, 07:09 AM Thread Starter
schapkern
any way to check it in the barn?
post #8 of 16 Old 12-02-2011, 08:55 AM
KJK
If it's that slight of a pull probably not. It could be any minor thing that causes it. You need a good alignment guy that knows that just because everything "appears to be in spec" that it could still pull slightly and he knows where to look to fix it.
Are all the tires at the same pressure? Same make and size?
KJK is offline
post #9 of 16 Old 12-02-2011, 09:10 AM Thread Starter
schapkern
tires are all same make model and size, trail mark radial 235 70R16's and all are inflated to 35.5 psi (digital guage)
I'll take your advice and take it to another tire shop for an allignment check
post #10 of 16 Old 12-02-2011, 10:12 AM
TheHalfWit
Yea, that just sounds like your wheel needs to be centered. I'd bet the tech doing it didn't know that with the zj and similar jeeps that the steering wheel is centered via the drag link.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #11 of 16 Old 12-02-2011, 11:06 AM
totalalign12
Good advice.
post #12 of 16 Old 12-02-2011, 11:17 AM
PolkaPower
Inspect all of your tie rod ends and track bar for play. If any of those are worn out then the alignment won't do any good. Worn out control arm bushings will cause a drift as well.
PolkaPower is offline
post #13 of 16 Old 12-02-2011, 05:56 PM
peter_zabriskie
Are you driving on a "flat" road? Around here(Indiana) roads with high crowns will require steering into the high side of the road or the Jeep will drift to the shoulder. This is with both of the my old sloppy ZJ's.
-Pete
Maybe off topic, but my '97 ZJ has about 1" of play in the steering wheel. Per another thread I reached in and wiggled the steering shaft where it goes into the steering box, that is where my play is. The shaft rotates about 1". Any adjustment for that? Or am I looking for a new steering box? I am pretty comfortable with how it tracks and steers now, but if it can tighten up that would be cool. My old '93 ZJ was much looser.
-Pete
Bravo Zulu
peter_zabriskie is offline
post #14 of 16 Old 12-02-2011, 09:46 PM Thread Starter
schapkern
-Pete
-Pete
driving in and around evansville or out in the country. In the country it was worse. Got an appointment with the shop tomorrow may know more then.
No play in the steering input shaft. I checked that, Dad thinks its my box bypassing internally but i doubt it...
Thanks for the help guys
post #15 of 16 Old 12-02-2011, 09:51 PM
KoreaZJ
1994 ZJ
Drag link collar is easy to adjust, two clamps with nuts. Center the tires, loosen the clamps, turn the collar with channel locks, vise grips, pipe wrench until the wheel is centered. Tighten the clamps good. Drive to verify.
KoreaZJ is offline
help needed , steering , steering alignment
Im tired of chasing this ticking when turning fr33zypop ZJ Grand Cherokee Forum 7 08-08-2011 09:06 AM
Steering Issue? MilwaukeeZJ ZJ Grand Cherokee Forum 3 06-06-2011 08:49 PM
94 gc limited radio issue/steering issue? r34civic ZJ Grand Cherokee Forum 7 01-04-2010 06:00 PM
Tired of chasing rainbows. Driveline vibes. crashcraddock ZJ Grand Cherokee Forum 3 05-19-2009 07:29 AM
Odd steering issue. vomfeinsten ZJ Grand Cherokee Forum 10 05-01-2008 10:02 PM
